Intense ECU Installed!!!
Old Jun 7, 2006 | 12:15 AM
BooSSted's Avatar
After waiting 2 months for my GM kit, I finally cancelled the order and ordered the Intense Stage 5 ECU, 60lb Injectors and Harness. I got everything in the mail Monday morning and I had it installed this morning along with my Billetflow 2.7" Pulley.
Let me tell you.....This car ******* screams now. from a roll in second gear it is a tough job for both the clutch and the tires to keep making forward progress. The boost hits sooner and harder than I could have ever imagined and it doesn't stop until 7000rpm!! The feeling is unreal.
I am hoping to be able to get to the dyno sometime this week. I want to check out the a/f ratios to make sure everything is in check and that CAI isn't causing any problems. I will post the results when I have them.
Awesome work Intense, keep the good stuff coming!
Old Jun 7, 2006 | 12:26 AM
CobaltSS422's Avatar
did u send your pcm in ahead of time of did u get a new pcm programmed with stage 5 and send yours back to them?
Old Jun 7, 2006 | 12:30 AM
BooSSted's Avatar
They sent me a new ECU.
I have to run to the dealer tomorrow to get the Crank Position Sensor code cleared but the car is running 100%
Old Jun 7, 2006 | 12:31 AM
Joewit's Avatar
DONT run it to 7k without doing CASE relearn first you could damage your engine permanently, only half throttle
Old Jun 7, 2006 | 12:34 AM
BooSSted's Avatar
The CASE relearn is done. The scanner that was used just couldn't clear the code for some reason.
Old Jun 7, 2006 | 12:37 AM
Joewit's Avatar
ok just makin sure cause i know some people on here ingnore that half throotle thing
Old Jun 7, 2006 | 02:22 AM
What did u tell the dealer? Don't flash the computer and just perform the CASE with a Tech 2 scanner? I'm nervous about buying the Stage 5 because I don't want my dealer to screw the thing up by flashing it and erasing the new tune
Old Jun 7, 2006 | 02:28 AM
ReMz's Avatar
damn. get that dyno asap! ... i wont be going with the Intense kits any time soon.... but i love to hear about it.
Old Jun 7, 2006 | 09:56 AM
BooSSted's Avatar
I havn't been there yet. The shop that did my install had access to a Tech II scanner but it didn't have the 2006 update to clear the code. I am going to bring the car to a different dealer than the one I bought it from and have them do it so I won't be givin a hard time if I go in for warranty work. The ECU comes with an information sheet that tells the tech exacty what to do. It has nothing to do with a full re-flash
Old Jun 7, 2006 | 10:13 AM
player_1's Avatar
that doesn't make sense how can a scanner clear you code and not the tech 2?
Old Jun 7, 2006 | 10:19 AM
BooSSted's Avatar
The tech II can clear the code. The one we used didn't have the full 2006 update so it couldn't clear the code off the ECU. From what I have been told, the scanners at the dealerships are updated every 2 weeks. I had mine done in a small shop, not the dealer
Old Jun 7, 2006 | 10:40 AM
snarkee's Avatar
when and where u going for dyno....i want mine done
Old Jun 7, 2006 | 10:48 AM
player_1's Avatar
what a mean is even the code scanners you buy at canadian tire can clear that code, I find it odd that the Tech 2 can't.
I know because I have the p0017 code ( cam to crank angle) that comes on because of my cams and I have had it cleared many times.
Old Jun 7, 2006 | 11:42 AM
2006ArrivalBlueSS's Avatar
I would love to see your car run at the track....come with us on Sunday!!
https://www.cobaltss.net/forums/canadian-mid-east-111/occ-test-n-tune-%40-cayuga-sun-jun-11-a-22042/
Old Jun 7, 2006 | 11:56 AM
BooSSted's Avatar
Can't go on Sunday. I am playing in a golf tournament. It's supposed to rain too
Old Jun 7, 2006 | 12:05 PM
OK then, I'LL take your car to the track and you drive mine to the course
Old Jun 7, 2006 | 12:10 PM
BooSSted's Avatar
Hahahaha, thanks for the offer but I'll pass
Old Jun 7, 2006 | 12:14 PM
Yeah, you'll pass alright - right by me like I'm standing still with your new set up Next time, have fun golfing!!
Old Jun 7, 2006 | 01:45 PM
BooSSted's Avatar
Just got back from the dealer. No problems, Car works perfect, no CEL
Old Jun 7, 2006 | 01:46 PM
Acidangel_5.0's Avatar
what kinda boost #'s u seeing? and why the 2.7 and not 2.5?
Old Jun 7, 2006 | 01:49 PM
BooSSted's Avatar
Boost is at least 17 Psi, I don't pay a lot of attention to the guage when driving, especially at WOT.
I may upgrade to the 2.5 but the 2.7 is working great for me right now. Less chances to break things with the 2.7 as well
Old Jun 7, 2006 | 01:55 PM
SS4ME's Avatar
Does anyone know how much a Tech 2 costs? I have been searching the past few days and can only find hard facts, no pricing. I imagine it is quit expensive!?
Old Jun 7, 2006 | 01:56 PM
BooSSted's Avatar
I don't think you want to know how much it is, haha.
Old Jun 7, 2006 | 01:58 PM
SS4ME's Avatar
Come on, all I need is a figure!
NightriderCobaltSS's Avatar
Also depending on what 2.7 your using he would need supercharger snout . With INTENSE anything below and 2.8 needs a supercharger snout. but with ZZP
" pulleys do not require snout maching. By developing Ecotech specific pulleys we run all the way down to 2.6" w/o snout machining."
Also Stage 5 is alot of money
"INTENSE™ LSJ Stage 5 Performance Package
Quantity in Basket: none
Code: LSJ-Stage5
Price:$999.99"
