Intercooler pump inlet/outlet
Old 04-29-2018, 09:04 AM
Stumpalump's Avatar
I'm plumbing a new chassis and can't tell from the contradicting internet pics what side of the stock intercooler pump is the input and output? One is straight on the end and one comes from the side. What one is which?
Old 04-29-2018, 11:20 PM
Stumpalump's Avatar
Does the stock heavy aluminum bracket do anything other than mount the pump? I'm thinking about ditching it because it doesn't seem to do anything other than hold the pump and its heavy.
Old 04-29-2018, 11:40 PM
Sharkey's Avatar
the fitting inline with the motor is the inlet, the one coming out the side is the outlet.
the aluminum bracket just holds the pump, if you have a better way to mount it you can ditch it.
Stumpalump (04-30-2018)
Old 04-30-2018, 11:18 AM
Stumpalump's Avatar
Thanks Sharkey! The bracket, tiny tab and bolt weighed 1.5 pounds. All the metal, bolts and tabs I used to mount the radiator and intercooler were under 4 pounds. I'm putting every piece on a scale and even orienting things like the pump the right way the first time to save a foot of fluid filled heater hose that I don't need.
Old 04-30-2018, 07:22 PM
Johnny Bliss's Avatar
same in and out like a turbo
NicossGuerrera
11-08-2011 12:37 PM
LSJ
06-17-2011 07:30 PM
speedyd
06-01-2009 09:55 PM
CobaltSS313
08-02-2007 03:56 PM
Ardskoay
09-22-2005 06:49 PM
Quick Reply: Intercooler pump inlet/outlet
