Muffler inlet/outlet question
Old Jun 14, 2011 | 10:34 PM
LSJ's Avatar
LSJ
I am buying a Dynomax Super Turbo muffler. Part #17748, it is 2.5", and it says offset/center. (I believe this is the largest 2.5" Super Turbo they make).
My question - Does it matter which side I use for the inlet? I'm fairly sure it doesn't, but I know glass-packs can be "reversed" for different sounds.
Lastly, would a offset/offset be quieter than a offset/center? I read somewhere it might make it quieter.
Thank you guys
Old Jun 15, 2011 | 03:01 PM
Hockeyman's Avatar
i'm running an offset/offset superturbo but it's a 3", I believe it fits a lot better if both sides are offset.
Old Jun 15, 2011 | 10:39 PM
LSJ's Avatar
LSJ
Really? I thought offset/center fit nicely but then again I haven't owned anything else.
What was the part number of yours? I want the biggest one in 2.5" that I can get!
Is it quiet? Are you catless?
Old Jun 16, 2011 | 02:49 AM
Erick161's Avatar
offset/center...
Old Jun 16, 2011 | 03:12 AM
Omega1x's Avatar
Deff. get center/offset
Old Jun 16, 2011 | 11:08 AM
LSJ's Avatar
LSJ
Originally Posted by Erick161
offset/center...
Center inlet, offset exit? You guys are confusing me! Thank you though I appreciate it!
Old Jun 16, 2011 | 11:32 AM
olivecj's Avatar
The one your buying will be fine. I have a dynomax superturbo ofset/centre muffler and it fit with no issues. The sound is good to not raspy or loud. Post a vid once you get it installed.
Old Jun 17, 2011 | 12:33 AM
Hockeyman's Avatar
It's very quiet cruising and at low rpms, from 3-3.5k there is a rasp due to being catless. When I lay on it, it barks pretty good.
Old Jun 17, 2011 | 02:27 AM
dtowngreg's Avatar
how about center/center on a 2.2( 2lt) that has na/ss bumpers?
Old Jun 17, 2011 | 09:06 AM
olivecj's Avatar
Not sure it may I just went by what others have said and everybody found the center/offset fit perfectly. It did for me anyway.
Old Jun 17, 2011 | 12:12 PM
dtowngreg's Avatar
hmm ok. well i seen some that said specifically for cobalt. and they had center/center and the offset/center. so maybe they can make it fit
Old Jun 17, 2011 | 03:08 PM
olivecj's Avatar
yeah exactly man worse comes to worse if it doesn't fit then you'll know you need to get a offset/centre instead.
Old Jun 17, 2011 | 04:04 PM
dtowngreg's Avatar
i already bought it lol i saw other exhaust for a cobalt with center/center and i assumed it would work.
Old Jun 17, 2011 | 04:18 PM
olivecj's Avatar
just exchange it if it doesnt fit problem solved
Old Jun 17, 2011 | 04:20 PM
dtowngreg's Avatar
i bought it used on amazon. its a magnaflow 11216. i saw this vid on a ls
YouTube - ‪cobalt magnaflow muffler‬‏
in the comments he says its a 11216. do they ever make the same part/series number with different inlet and outlets
Old Jun 17, 2011 | 04:48 PM
olivecj's Avatar
you'll be fine man magnaflow mufflers usually don't have any issues with fitment.
Old Jun 17, 2011 | 07:30 PM
dtowngreg's Avatar
thanks hope so
Supercharged06SS
Dec 11, 2022 04:47 PM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
