Car wont start?
Long story short, I had the block torn all the way down and rebuilt it this weekend. Got the engine, trans, and cradle all back up. Stock blower installed, all wires reconnected, tires on and back on the ground. Added oil, coolant, haven't bled the clutch yet. Rewrote the ECU with the stock tune.. cranked and nothing? The only noise it made was the starter solenoid, one loud audible click and nothing afterwards, no cranking at all. The battery has good voltage, above 12v, and when turning the key the voltage does not drop at all. All fuses check out as well. My buddy and I are leaning towards a bad starter. Anybody else have a clue?
I'll have to check, if not tonight then tomorrow. Do you happen to know where the ground goes from the frame rail that is located under the driver side headlight? I thought it went to the starter but looking at pictures of GMPD engine removal guide it doesn't look like it goes there.
Hmm thought we did, guess not. Just checked the drop from the power wire coming off of it at the fuse block. No drop in voltage.
Battery was disconnected throughout the process and is securely connected now. I think I know where I messed up. I grounded a wire to power lead to the starter. I'm so use to working on heavy equipment vehicles at work that have ground wires on the heavy duty starters. When I get home I'll put that ground in the right place and pray my starter solenoid is still intact.
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
