Cat-back exhaust
Old Sep 14, 2006 | 06:15 PM
jerzeedevl's Avatar
Cat-back exhaust
who has done a cat back system themselves? i bought the corsa cat back exhaust system from cobalt-addiction.com.
im gonna put it on myself and was wondering if its a direct fit
Old Sep 14, 2006 | 09:00 PM
postal_ss's Avatar
direct fit
it should be a direct fit.
i just put a monza caatback on and all i needed to get were 2 new nut and bolts to attatch to the cat pipe(or what ever its called)
Old Sep 14, 2006 | 09:04 PM
Strider_2001's Avatar
The hardest part is cutting the old muffler off....After I got that cut off it took literly 15 minutes...
Old Sep 14, 2006 | 10:43 PM
random1121's Avatar
ya it's a direct fit should be no problem, but if you run into any problems come on here and let someone know.
Old Sep 16, 2006 | 02:35 PM
jerzeedevl's Avatar
why did u have to cut off the muffler? shouldnt it just pull right out with the rest of the piping?
Old Sep 16, 2006 | 02:40 PM
D4u2s0t's Avatar
you have to cut the muffler off because the pipe is too long and won't manueavuer (sp??) over the rear axle... one cut by the axle and it will pop right off...
as far as ease of installation, i did mine myself with my father... it took us about 45 minutes, and i have never installed an exhaust before... piece of cake... unbolt the old exhaust from the downpipe (what someone ^^ referred to as the cat pipe) take off the rubber hangers and cut the muffler... then just bolt the new pipe to the downpipe, (keep it loose for now) hang the pipes on the rubber hangers, and get everything in place... give a good tighten and you're good to go... drive it for a while, listen for rattles... if it sounds like something is loose, tighten it up...
now keep in mind that if you have been driving, the pipes are going to be HOT!! especially the downpipe... so be careful to not burn yourself...
Old Sep 16, 2006 | 03:09 PM
jerzeedevl's Avatar
ooooooooooooooooooooo ok thanks a million D4 i cant wait to hear what it sounds like
what do u use to cut it off if u dont have an air tank and air tools?????
Old Sep 16, 2006 | 03:15 PM
cvenom2122's Avatar
hack saw
Old Sep 16, 2006 | 03:18 PM
D4u2s0t's Avatar
u can use a hack saw, or a sawsall or something like that... a regular hacksaw would work fine, just may take a little longer...
and youre welcome
Old Sep 22, 2006 | 07:19 AM
postal_ss's Avatar
sawzall
i had to cut infront of the axle in a bend at th weld,so if i had to replace it would take a smaall pipe and 2 clamps.....2 mins to cut
Old Sep 22, 2006 | 08:13 AM
bdwarr6's Avatar
Get a can of wd-40 an 15mm wrench and your good to go
The bolts to the catalitic converter are 15mm, spray them with some wd forty and let them sit for 30 or so seconds. then remove the two bolts. I suggest cutting the old exhaust at the weld near the back tires, once cut remove the black rubber things that hold it on. (if they are hard spray some wd-40 on them). then just stick the corsa in.
I did mine yesterday I spent longer looking for something to cut the stock exhaust out than I actually did working.
edit
if you want to do this right after you finish driving get your garden hose and spray the heck out of the exhaust and bottom of the cat.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
Sep 27, 2015 08:53 PM
