catback help
Old Oct 1, 2007 | 07:19 AM
Deathcult's Avatar
catback help
i need all the info on how to remove the kitty from a stock exhaust. i want to test the sound and i want to test the car with it and without it. i know nothing about it and i have the day off. its time to know the difference between catback, and catless
how do i remove it, what exactly is a catalyst, will anything bad happen to my car, like it bogging down or anything?
im bored and i want to play with the car a bit =)
meow
Old Oct 1, 2007 | 02:00 PM
Deathcult's Avatar
29 views and nothing...so uhhh bump =P
Old Oct 1, 2007 | 02:56 PM
ebristol's Avatar
There is no way to remove the cat temporarly and then put it back on. If you want to find out the difference while still keeping your stock setup you should buy a used cat from someone on here and gut it. Or by catless dp from zzp.
Old Oct 1, 2007 | 02:59 PM
D4u2s0t's Avatar
it will be louder, and more raspy. you will have to cut it out, weld in a pipe, and then cut the pipe, and re-weld in a cat.
09SSlow
Sep 28, 2015 12:37 AM
ROADKONE
Sep 9, 2015 02:32 PM
Rayray2781@gmail.com
Sep 9, 2015 10:40 AM
jgdaly
Sep 8, 2015 04:14 PM
