Catless DP Installed, Some Questions
Old Apr 7, 2010 | 07:40 PM
BKTG1's Avatar
Hey guys, I just put a custom made 3" catless downpipe on my car, I was going to put the gm honned manifold on as well but i couldn't get the two bolts by the drivers side that hold the stock one on, so i just put the dp on. I replaced the gasket from header to dp and dp to catback. When i started the car everything sounded fine, but when it started warming up it starting smoking by the headers and it smells kinda like something burning , i'm thinking this is just the new gaskets "burning" in, but i just wanted to see if it is or if its a leak or something. Also am i going to have any problems going from a catted dp to a catless? I dont think i should as I have a zzp pcm, but just wanna make sure.
Old Apr 7, 2010 | 08:35 PM
the919Phenom's Avatar
hey
zzp pcm should have the rear o2 bung delete. to run catless or high flow cats.
what did u do to the bung you took out of ur stock down pipe? is anything touchin the new dowpipe. if not u should be fine.
i had a wierd smell and little smoke, when in put my new dp on. but it was just the first time heatin up the new pipe
Old Apr 8, 2010 | 08:05 AM
jmarks's Avatar
The smoke is from the grease that was most likely on your hands when you installed the dp.
Old Apr 9, 2010 | 09:23 AM
hey
yea now that i think about it. mine smoked from the wd-40 burning off. lol
Supercharged06SS
Dec 11, 2022 04:47 PM
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Bohb
Sep 27, 2015 09:11 PM
