Cel!?!?!?!
Old Jun 8, 2006 | 10:46 PM
Re4peR26's Avatar
Cel!?!?!?!
Well i did my intake mod n **** well after driving it for a day i got CEL so should i just reset it?
Old Jun 8, 2006 | 11:06 PM
Re4peR26's Avatar
Old Jun 8, 2006 | 11:07 PM
zinner's Avatar
Moderator Alumni
LMAO you need to bump after 20 minutes. You should find out what the code is first.
Old Jun 8, 2006 | 11:15 PM
g5mike's Avatar
post the code you are getting and someone should be able to tell you what it is
Old Jun 8, 2006 | 11:20 PM
StreetDreamz's Avatar
MAF out of range, blah blah blah. Run it for a while, then get it reset. It should stay off.
Old Jun 9, 2006 | 10:41 AM
Re4peR26's Avatar
I went to autozone and they said it was runing lean? any suggestions??
Old Jun 9, 2006 | 11:44 AM
alleycat58's Avatar
What brand intake?
Injens and AEMs tend to throw no codes at all. I have a Fujita but only get a code when the filter needs cleaned. K&Ns tend to throw codes a lot.
Old Jun 9, 2006 | 12:13 PM
06blackg85ss's Avatar
did the intake mod myself, used k&n e-1009, no cel had it on for a month already, through rain and whatnot.
Old Jun 9, 2006 | 12:17 PM
alleycat58's Avatar
Yeah, if you just did the airbox mod, it typically doesn't throw a code unless your filter is loose. If that's what you did, Re4peR26, then check the clamp on the filter and make sure it's on there nice and tight.
Old Jun 9, 2006 | 12:40 PM
check the tubing too, all the hose clamps... any air leak after the maf could cause it
turbochargedss2012
Sep 20, 2023 12:17 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
Dustin24
47
Feb 12, 2016 04:10 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
