CEL blinked for a few secs!! Why??? help!!?
Old May 14, 2007 | 11:10 AM
vextc05's Avatar
i was off to work at 9am. And when i hit 2nd gear the car kinda bogged alittle. And then the cel poped on blinking for 10 secs. Then it went away and the car seemed to run fine with no BOGS. Could this be cause the engine needed to be warmed up. I always get nervous when i see that damn CEL ligtht. And btw i have the intenese ecu with 2.8 pulley and 42.5 injectors if that means anything
Old May 14, 2007 | 11:13 AM
Jackalope's Avatar
From what I've heard a flashing CEL means death is right around the corner. You may want to get this one checked out ASAP.
M88ArRamadi's Avatar
I'd say Misfire P0300.....BUT you said it didn't bog down or studder......so IDK. Get it scanned and let us know
Old May 14, 2007 | 11:14 AM
Quicksilver83's Avatar
hmm, that is kind of weird. Yet the other day while on the interstate my ABS and emergency brake light turned on for a few seconds then turned off. It was the 1st time that ever happend and it hasn't happend since, also i'm bone stock except for the tires.
Old May 14, 2007 | 11:17 AM
kissmySS's Avatar
Flashing is the KEY word.. Not on and back off once.. If its staying on and blinking DONT DRIVE IT..!
Old May 14, 2007 | 11:57 AM
vextc05's Avatar
no it flashed for like 7 secs then stopped right away.
Old May 14, 2007 | 12:00 PM
Witt's Avatar
It flashes when it determines the engine is in a condition that will damage the catalytic converter. Usually happens from sustained detected misfires.
Old May 14, 2007 | 12:02 PM
vextc05's Avatar
so are misfires common Do i have anything to worry about?
Old May 14, 2007 | 12:04 PM
Witt's Avatar
Could have been poor gas or air in the line, maybe a wiring fault to the injector, anything really. Probably a ECM hiccup though if the light went out immediatly after doing it. It should stay on but not blinking for a couple more drive cycles.
Old May 14, 2007 | 12:23 PM
vextc05's Avatar
well could it be cause the engine needed to warm up. I mean it wasnt really that cold out, maybe in the 40s-50s. But it happened right away as soon as i left my driveway. And for 14 miles the cel didnt popped up again
what should my next step be? I get hella scared everytime i see that light!!
Jackalope's Avatar
Ohhhh! Thanks man I thought they were the same thing.
Old May 14, 2007 | 12:37 PM
06blackSC's Avatar
did you put in your summer air?
Old May 14, 2007 | 12:42 PM
Jackalope's Avatar
Yeah that could be it!
Old May 14, 2007 | 01:16 PM
vextc05's Avatar
ok so what should i next step be? Should i just not worry about and see if it pops on again? Should i get it diagnosed?
Old May 14, 2007 | 01:26 PM
Jackalope's Avatar
Yeah man if it does it again I'd take her in to get checked out.
Old May 14, 2007 | 01:27 PM
ssilver's Avatar
Mine did this about 3 months ago. CEL flashed a couple times really quick after I bounced off redline on accident. Never was too worried about it. GM cars seem to do it alot. My 04 silverado seemed to randomly flash a CEL quite often.
NGalaxyTimmyo's Avatar
Just take it up to an Autozone, they'll read it for free, and write down what the code is, and tell us
Old May 14, 2007 | 02:05 PM
bc3tech's Avatar
flashing CEL (not coming on, then going off after a while and coming back on again) is piston misfire.
Old May 14, 2007 | 02:27 PM
vextc05's Avatar
it just flashed for a few secs and then went off. And this is after it bogged in 2nd gear for alittle bit.
i will do this after i get out of work and ill let u guys know what it is
Old May 14, 2007 | 08:59 PM
vextc05's Avatar
my friend just did a diagnostic and nothing came up. THANK GOD!!!
turbochargedss2012
Sep 20, 2023 12:17 PM
Dustin24
47
Feb 12, 2016 04:10 PM
brandon04
Oct 21, 2015 07:04 AM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
