CEL on dryflow!!
CEL on dryflow!!
yep you heard it here. Just did the airbox mod with yesterday with the AEM dryflow, unhooked the neg. of the batt for a couple min then put it back on. Drove for about 25 miles and i got a CEL
so this morning i unhooked it for longer(10min) then it went away and then came back in a couple hrs.
before u ask yes it was the dryflow filter im not dumb. any advice, suggestions, help would be very appreciative
anyone!!!
so this morning i unhooked it for longer(10min) then it went away and then came back in a couple hrs. before u ask yes it was the dryflow filter im not dumb. any advice, suggestions, help would be very appreciative
anyone!!!
Last edited by EceSSiveMod; Apr 9, 2008 at 09:27 PM. Reason: Automerged Doublepost
Is the maf connected properly? Did you get any dirt on it at all?
Go to autozone and get a free codescan and let us know what code it is. That will help out a lot. For now i'd re-check the MAF connection. It's probably just loose.
wow I can understand your frustration since I got the dryflow to AVOID CEL's, not have them popping up and what not. I would say clean the MAF and unplug the battery for longer but who knows? My friggin' balt will throw power steering codes along with security codes along with a festival of lights at the dash sometimes. As long as it still runs, warranty gone bye bye today at 36001 miles!!
It's the sensor that is retained in the tube by 2 screws. Get some QD Electronic cleaner and spray it after you remove it from the car. If problems persist its probably the way is is flowing through your intake.
You can always take it to Autozone to get your code checked for free to really make sure what the culprit is.
i dont wana get back under their hahaha
just so you know if you decide to pull the maf its easier to get through the headlight socket just pull the headlight rather than the wheel well
and double check that everythings tight not just a visual inspection and also check the vac line on the tube between the throttle body and fender
Last edited by TRANSAM197781; Apr 10, 2008 at 06:16 PM. Reason: Automerged Doublepost
check for any leaks or bad seals in the tubing for the airbox mod, Mine was setting off the same code and it was due to a connection where the rubber piece was folded in and allowing extra air to get into the intake.
Are all years the same , or just the 07's with the new OS? I've had a Aem CAI on for the last 3 months and not one issue, before that was an airbox mod for over a year ..no cel . Wondering if it's a fluke or bound to happen eventually . I did have a P0171 the first week i bought it new but the dealer flashed an update that was supposed to take care of the issue .
Here's the TSB
#06-06-04-033: 2.0L/2.2L LSJ/L61 Engine Malfunction Indicator Lamp (MIL)/Service Engine Soon (SES) Lamp Illuminated with DTC P0171, Fuel Trim System Lean, Set (Reprogram ECM) - (Jun 21, 2006)
Subject: L61 Engine Malfunction Indicator Lamp (MIL)/Service Engine Soon (SES) Lamp Illuminated with DTC P0171 "Fuel Trim System Lean" Set (Reprogram ECM)
Models: 2005-2006 Chevrolet Cobalt, Cobalt SS Supercharged
2006 Chevrolet HHR
2004-2006 Chevrolet Malibu
2005-2006 Pontiac Pursuit (Canada Only)
2004-2005 Saturn ION Redline
2005-2006 Saturn ION
with Ecotec™ 2.0L or 2.2L I-4 Engine (VINs P, F - RPOs LSJ, L61)
Condition
Some customer may comment that the MIL/SES lamp is Illuminated. Further diagnostic investigation with a scan tool may reveal a DTC P0171 Fuel Trim System Lean. No other driveability or performance concerns may be reported.
Cause
The most likely cause of this issue may be that the engine calibrations need to be updated to correct a variation in the Mass Air Flow Sensor.
Correction
DO NOT replace the MAF sensor, the ECM or any other parts.
Important:
• Chevrolet/Pontiac Dealers: The ECM calibration is available to dealerships as part of TIS2000 incremental satellite update version 6.5, which was broadcast to dealers June 12, 2006 or later. For the dealerships that use CDs, they were mailed out June 2006 or later.
• Saturn Retailers: Before installing the new ECM calibration, make sure the Saturn Service Stall (SSS) version is TIS 6.5 2006 or later.
• While the ignition is OFF, apply the parking brake to disable the daytime running lights (DRLs) prior to starting reprogramming procedures
• The technician must select the "Reprogram" option in order to reprogram the ECM.
Reprogram the ECM with the latest calibration. This calibration, or any that follow, is designed to address this DTC P0171 concern. Refer to Service Programming System (SPS) in SI for reprogramming procedures. As always, make sure your Tech 2® is updated with the latest software version
Warranty Information
For vehicles repaired under the 8-year/80,000 mile (130,000 km) emission controller warranty, use:
Labor Operation
Description
Labor Time
J6353
Reprogram ECM with SPS
0.4 hr*
* U.S. Saturn Retailers: Refer to Saturn Electronic Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
And then there was this one for staged cars .
#PIP3868B: GM Performance Parts Stage 1 Or 2 Kits Only - SES Light With A P0171 DTC - keywords after calibration concerns controls driveability DTC engine engineering I II investigation kit LSJ MIL no PCM - (Oct 10, 2006)
Subject: GM Performance Parts Stage 1 or 2 Kits Only - SES Light with a P0171 DTC
Models: 2005-2006 Chevrolet Cobalt SS
2004-2006 Saturn Ion Redline
with 2.0L Engine (VIN P - RPO LSJ)
and GM Performance Parts Stage 1/2 Kit
This PI was superseded to remove the 2007 model year. please discard PIP3868A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
On rare occasions, an intermittent SES light may be encountered with a DTC P0171 and NO engine performance concerns.
Important: This PI only applies to vehicles that have a GM Performance Parts Stage 1 or Stage 2 Kit installed. For vehicles without a GM Performance Parts Stage 1 or Stage 2 Kit, see bulletin 06-06-04-033.
Recommendation/Instructions:
If the SI diagnostics do not isolate a cause for this concern, reprogram the ECM with TIS Version 9.0 or later, which contains ECM calibration updates to address this concern.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
© 2008 General Motors Corporation. All rights reserved.
Here's the TSB
2006 Chevrolet HHR
Condition
Cause
Correction
Important:
Labor Operation
Description
Labor Time
J6353
0.4 hr*
Condition/Concern:
anyone!!!
anyone!!!
but you dont know where the maf is
Last edited by hungryhip-ccp; Apr 12, 2008 at 03:09 PM. Reason: Automerged Doublepost
