CEL Questions
Old May 12, 2009 | 05:40 PM
victoryss's Avatar
CEL Questions
I have searched and found that P0036 and P0141 are related to the 2nd o2 sensor and being I removed mine last week after the new Header and DP went on, and put a wideband in. I am now throwing these CEL's what do I go under in hptuners to turn it off?
Old May 12, 2009 | 05:42 PM
Supercharged06's Avatar
i actually have thoes same codes, they just came up about a week ago
but i have a catted dp so im not really sure whats up
Old May 12, 2009 | 05:44 PM
victoryss's Avatar
If it's a high flow cat it can still cause them.... Check you fuses
Old May 12, 2009 | 05:46 PM
LSJAY's Avatar
Are you running just the wide band after the cat or both the post cat O2 and wide band?
Old May 12, 2009 | 05:48 PM
victoryss's Avatar
I am cat-less and I removed the rear 02 sensor and plugged an 02 in for my wideband
Old May 12, 2009 | 05:52 PM
LSJAY's Avatar
Well than thats why your cel is on because the readings for your wide band do not go through the factory PCM which it thinks there is a problem with the post cat O2.
Old May 12, 2009 | 05:53 PM
victoryss's Avatar
Tis what I though I jsut wanted to confirm thank you for your time
Old May 12, 2009 | 05:57 PM
LSJAY's Avatar
Not a problem.
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
