CEL random misfire?
Old May 9, 2010 | 12:57 PM
ecot3c inside's Avatar
CEL random misfire?
Every other day or so I get a check engine light that says p0300 (random cylinder misfire), My ss/sc runs great all the time. The cel either goes away by itself after 5 startups or I get tired of looking at it and erase it. This only started happening recently when I put my new 3" exhaust on. other mods I have is 3" pulley #42 injects. ottp tune. When I really step on the gas is when it happens more often. Yes I have 1 step colder plugs that cam with my kit.
Old May 9, 2010 | 01:42 PM
Mclovin23's Avatar
you might be running lean. ive seen it happen because of that. were your plugs pre gapped?
Old May 9, 2010 | 04:58 PM
no I gapped my plugs to the recommended ottp specs. lean is unlikely because I get terrible gas mileage.
Old May 9, 2010 | 06:14 PM
krazycobalt's Avatar
Just because you get terrible gas mileage it doesn't necessarily mean that you can't run lean
Old May 9, 2010 | 09:09 PM
idk, it could be a possibility, but I doubt it. any other suggestions please?
Old May 9, 2010 | 09:14 PM
revolution607@yahoo.'s Avatar
i know that code is common with 60# injectors but seeing how you have 42's i dont know why you would get that.
check your plugs
Old May 9, 2010 | 09:19 PM
check your plugs
I get it every once in a while, haven't gotten the chance to take a look at the spark plugs. Even if it is running rich or lean, the main problem here would be a re-tune correct?
Old May 9, 2010 | 09:23 PM
most likely, do you have any way of logging your car?
if you do get in touch with someone who understands tuning/hptuners and im sure theyll be able to help you out.
Old May 9, 2010 | 09:26 PM
Idk, I have a laptop scanner that I believe freeze frames and such, which would probably work.
Old May 9, 2010 | 09:46 PM
outtamymind's Avatar
you said it only started happening since you put your exhaust on. did you do anything to the header or downpipe
Old May 9, 2010 | 10:20 PM
nope, just a catback exhaust.
turbochargedss2012
Sep 20, 2023 12:17 PM
717ssbalt
Oct 2, 2015 04:01 PM
DocSvensk
Sep 27, 2015 02:24 PM
jmelton327
Sep 26, 2015 10:04 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
