Changed bpv, still boosting 3 psi
I just changed my bypass valve but I'm still boosting at 3psi. Anyone know any other factors to the low boost problem.
I have had this problem going on for a while now. I got my alternator changed at the dealer, had issues with battery light so in the process they swapped the ecu module... I figured i lost my tune and was boosting low because of that. Couple months later got the money for a new tune, changed the bypass valve and still boosting at 3 psi
Any ideas?
Any ideas?
Yeah I would take it back to the dealer but it was like august when they fixed it, I figured they wouldn't even know what i'm talkin about or something or say it's too late. I honestly thought it was the tune at the time.
I will try a boost leak check.. Do i just get someone to rev up a bit while i listen for some air and stuff?
No you make a boost leak tester and a 2.75" coupler and hook it to your throttle body. Then you pressurize the system with an air compressor and spray soapy water any where air can leak. Then listen for leaks and watch for bubbles. I found I had a leaking injector seal by doing this. It's more of a turbo car thing to find leaks in the intercooler piping but it works for your intake manifold and such too.
http://www.youtube.com/watch?v=u3Kqh52PC6Q
Here's a video to make one. You don't need the gauge on it mine doesn't have it. All you need is the tire valve stem. Really easy to make and only about $10. All you do is get that pvc piece drill a hole and put a standard tire valve in there easy as that. I bought a 2.75-2.5 coupler for the cobalt since the throttle body is 2.75" and the pvc piece was 2.5''.
No you make a boost leak tester and a 2.75" coupler and hook it to your throttle body. Then you pressurize the system with an air compressor and spray soapy water any where air can leak. Then listen for leaks and watch for bubbles. I found I bad a leaking injector seal by doing this. It's more of a turbo car thing to find leaks in the intercooler piping but it works for your intake manifold and such too.
Boost Leak Testing 101: Building the tool. - YouTube
disconect the vaccum line coming from the intake and plug that will bypass the boost bypass solenoid then see what it does when you drive and have you tried swapping out the boost guage to see if it is bad
I have not tried swapping boost gauges.. i guess i could try that with my friend who has SS/SC also. And i will try bypassing the solenoid as soon as i find something to plug it with lol.
Yes, it feels slower from when i used to boost around 16ish psi. And i got it retuned by vince.
Nah i used the ez flash program to put the tune on my car and vince emailed me the tune. I will mess with that line as soon as i get the chance...
