Changed pcm car wont run?
Old Mar 10, 2009 | 10:37 PM
timhebert's Avatar
need some help. changed my psm now my car wont run with stock or tuned pcm.
any ideas
Old Mar 10, 2009 | 11:06 PM
jasongrace16's Avatar
wow looks like no one has a clue.....Bump
Old Mar 10, 2009 | 11:08 PM
Darkmanx's Avatar
do a relearn.
Old Mar 10, 2009 | 11:13 PM
TRANSAM197781's Avatar
Probably a little more info would help people help you . Did it start at all ?Did it start and die? Did you get the pcm from the garbage.
If you gave some more information i might help people help you did it start at all did it start and die
Last edited by TRANSAM197781; Mar 10, 2009 at 11:13 PM. Reason: Automerged Doublepost
Old Mar 10, 2009 | 11:15 PM
WVsuperSS's Avatar
if you got it from intense you have to follow the re-learn program...... haha i just changed mine, so follow the directions it came with, it takes about thirty minutes......
Old Mar 11, 2009 | 10:10 PM
timhebert's Avatar
i got it from ott. i did some relearn thing. it stated ran wierd died and wouldn't start again
its the tuned pcm that comes with the kit. check engine light is on to but im not sure it that stays on till car is stated or not
Old Apr 20, 2009 | 10:03 AM
stonny9's Avatar
any more info on this? I have an 05 pcm went bad so I put an 06 pcm and it runs fine but I wanted the gas guage to work correctly so I got another 05 pcm. It is a pcm that came from a car with 1500 miles. Did the vin change and every thing loaded correctly with no cel but the car wont even turn over.
What relearn are u talking about because I did the crank case relearn on the 06 pcm that is in the car now where u rev the engine.
I have stg 2 but was just trying to get the car started with the stock tune that was in it before I loaded the stg 2 tune but that should not keep it from starting or at least attempting to start.
Old Apr 20, 2009 | 10:15 AM
stage2cobaltss's Avatar
lsjwannabe thats sean he'll help u out if its the pcm ( from ott )
Old Apr 20, 2009 | 10:38 AM
383_Stroker's Avatar
battery dead?
Old Apr 20, 2009 | 10:59 AM
stew_pidaso59's Avatar
Originally Posted by 383_Stroker
battery dead?
Old Apr 20, 2009 | 01:15 PM
krazycobalt's Avatar
haha battery died!!!
Old Apr 20, 2009 | 01:16 PM
Bika's Avatar
Fail Less.
set VATS, do a CASE learn.
if problem persists, burn car.
Old Apr 21, 2009 | 05:14 PM
timhebert's Avatar
i took it to a shop adn got a case relearn its all good know thanks for all the help
OrngBalt
Sep 16, 2015 07:45 PM
Sean Cummings
Sep 11, 2015 09:35 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
09BlkCrusader
Sep 9, 2015 04:47 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
