changing my meth setup!
Old Jun 16, 2008 | 05:20 PM
thatotherguy's Avatar
Ok guys do you think this will work? im shooting meth into the TB spacer i bought, and i was thinking of branching off the lines so i have one line into the TB and under the supercharger. so there will be meth going into the supercharger and after it.. I know you have to turn the pump up more, I want to see if this works. because i just want to cool down the temps the supercharger makes
Let me know thanks guys!
Old Jun 16, 2008 | 05:21 PM
invisible's Avatar
I would just use one. You are gonna shoot to much in there with 2 jets.
Old Jun 16, 2008 | 05:23 PM
I know but that would cut my fuel down alot since im running 79lbs right?
Old Jun 16, 2008 | 05:24 PM
invisible's Avatar
No, it would make it rich and you would loose power.
an0malous's Avatar
spraying another line after the blower will not do anything more than spraying the same amount through one jet before the blower.
in fact, probably less.
just get a bigger jet.
Old Jun 16, 2008 | 05:26 PM
k k, i was gonna see if anyone has done this before. but thanks yall
Old Jun 16, 2008 | 05:29 PM
an0malous's Avatar
you could always pully up so that your m62 isnt a flamethrower...
Old Jun 16, 2008 | 05:34 PM
yeah lol i know.. ive been running that 2.5 for 30k miles now and i know the supercharger is about to go out im sure. but when it does im throwing a procharger on it
Old Jun 16, 2008 | 05:35 PM
an0malous's Avatar
good answer
Old Jun 16, 2008 | 05:40 PM
Originally Posted by denny
I sooooo....want to try this. I have been thinking about this setup for a while. The nozzle before the SC could be 200cc and it would cool the blower nice and then another 200cc after the SC to cool down the cylinders. Am sure the blower eats up the water and meth and leaves nothing to really cool down the temps of the cylinders.
i think all the meth that goes into my blower drys up before intering the manifold.. im running a 2.5 pulley
Old Jun 16, 2008 | 05:41 PM
invisible's Avatar
Have you dynoed though?
Old Jun 16, 2008 | 05:42 PM
Area47's Avatar
Rent me! per hour
you would be amazed at what meth does to cylinder temps.
before and after was an average of 300 degree's in egt temps
an0malous's Avatar
you could quite easily test your theory.
check your AFR and EGT before and after meth.
i think youd be surprised how much is getting through
Old Jun 16, 2008 | 05:47 PM
Nope i havnt yet.. im getting it back from the shop this week sometime. i ran the 2.5 maybe 2 months before it blew up. #4 piston cracked in half and the other 3 had big pieces missing
Old Jun 16, 2008 | 06:53 PM
How much PSI where you putting out? I limited my 2.6 to 17PSI to be safe..... even at that my AIT2 still shoots up to 160 max....
the most i hit was 21.5psi... i think im pretty high over sea level here
Old Jun 16, 2008 | 07:45 PM
Z Speed's Avatar
wow Im only seeing about 115 degrees and all i have is meth and front mount... waiting for my option b and dual pass to show up
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
