Changing pulleys?
Old Aug 15, 2010 | 11:20 AM
Joemaster70's Avatar
Changing pulleys?
if i get the multipulley system how hard is it to change the pulley after the hub gets pressed on
Old Aug 15, 2010 | 11:24 AM
cmatthewb101's Avatar
Unscrew screws. Put new pulley on, put screws back in
Old Aug 15, 2010 | 11:36 AM
whats a better system zzp,ottp or modernperformance nonslip ones
Old Aug 15, 2010 | 12:42 PM
stonny9's Avatar
I can change a pulley in 5 mins with a chisel to loosen the belt and an allen key to remove the bolts
Old Aug 15, 2010 | 08:23 PM
InfraRedline's Avatar
Its very simple. I have done it a few times in between classes in the campus parking lot
Old Aug 15, 2010 | 08:28 PM
don't u need to tune while u change ur pulleys if u go smaller or larger?
Old Aug 15, 2010 | 10:08 PM
Karlen89's Avatar
If you're stock, dont drop pulleys without going bigger injectors.
and ya, youll need a tune
Old Aug 15, 2010 | 10:19 PM
just bought 42's w/ harness and a smoothflow 2.9 polished and tryin to get my hands on a stg2 belt and a hub for the pulley. also wat spark plugs r needed colder 1 or 2?
Old Aug 15, 2010 | 10:27 PM
mexi_loco's Avatar
you don't need to change spark plugs. But you could if you want. And if you don't find a belt, you can always get an oversized tensioner pulley.
Old Aug 15, 2010 | 10:37 PM
will the ZZP modular pulley hub work with my smoothflow pulley or do i need to buy the ottp gm stage 2 hub and allen screws
Old Aug 15, 2010 | 10:40 PM
Karlen89's Avatar
You could look up on smoothflowpulleys.com for the hub and all of that jazz.
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
