changing rear brake pads.. wtf?
Old Apr 29, 2008 | 07:04 PM
Nussle's Avatar
Question changing rear brake pads.. wtf?
im changing my rear brake pads and im using a C clamp which i used for the fronts yesterday to push the piston in and it worked easily but the rear piston is not moving at all. is it supposed to be done some other way or what?
Old Apr 29, 2008 | 07:06 PM
alleycat58's Avatar
Rear piston screws in, it doesn't push in. Try needle nosed pliers and turn it.
Old Apr 29, 2008 | 07:32 PM
06blackSC's Avatar
the rear calipers/actuators use a simultaneous "squishing" and rotating the piston in a clockwise direction. Most of the the time (and especially on cars as new as our) you can use needle nose pliers in the two little slots in the piston and push and turn the piston all the way in. Just make sure you don't damage or tear the dust boot for the piston.
Old Apr 29, 2008 | 07:33 PM
BOOSSTED 06's Avatar
as alley said, just use needle nose pliers and twist it in, it will turn really easy
Old Apr 29, 2008 | 07:38 PM
MikeyMo84's Avatar
theres a little tool you can use that attaches to a ratchet that does the job still a pita tho
Old Apr 29, 2008 | 07:39 PM
rallyracer's Avatar
Also, make sure you E brake is not on.
biniecki
Oct 25, 2015 02:23 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
