changing stage 2 pulley?
Old Jul 24, 2007 | 12:04 AM
ssaddiction's Avatar
do you need special tools to change the stage 2 pulley to a 2.9 and is it safe to run on the stage 2 tune? how do you change a pulley?
Old Jul 24, 2007 | 12:07 AM
KillerBee's Avatar
Well it depends if you have the stock one on or not if so you need a pully puller but if not and you have the gm stage 2 kit it comes with special tools to take out the bolts
Old Jul 24, 2007 | 12:11 AM
RedEcotecSS's Avatar
its a BITCH to do it. lol. good luck man, just make sure the dealership that installed your stage 2 give you the 'keys' back.
Old Jul 24, 2007 | 12:15 AM
is it hard to get the belt off it?
Old Jul 24, 2007 | 10:52 AM
OnebadaSS_SC's Avatar
Help
Do you really need to get a better tensioner if I want to change the pulley to 2.79"? Wont the belt be good enough?
Old Jul 24, 2007 | 11:01 AM
To get the belt off, you'll need something to push the tensioner pulley down. I think you can use a 15mm wrench but i'm not sure. Pulley Boys also sells something to push your tensioner pulley down, that's what I used, loved it.
I believe, if you have the GM stage 2 belt on you may not need a tensioner. Might want to pass that by someone else also.
Old Jul 24, 2007 | 04:13 PM
LopsidedJester's Avatar
i had a problem with the 15mm wrench rounding off the piece that you need to push and compress, but i took a slightly smaller english unit wrench which was tighter and it worked great (had to do a little pounding to get it on). After that, as long as they didn't tighten your pulley screws too much and you still have the keys that they gave you with stage 2, it should be easy. Took me about 25 minutes.
DarrenGC
Dec 24, 2021 01:55 PM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
