Check engine code....
Old Feb 11, 2008 | 06:06 PM
The Punisher's Avatar
P0171 Fuel Trim System Lean ECM, PCM
.I'm guessing that is saying I am running lean? My wideband is reading around 14.5 under normal driving...WOT is around 13
I also had another code...P2261
Cylinder 1 injector circuit low....
any enlightenment would be greatly appreciated..
thanks
Old Feb 11, 2008 | 06:14 PM
Area47's Avatar
Rent me! per hour
loose injector connection.
the 171 code is from your fuel trims. nothing to do with afr
Old Feb 11, 2008 | 06:19 PM
an0malous's Avatar
doesnt mean your running lean.
it means that fuel trims are working extremely hard to KEEP you from going lean.
on a custom tune are you?
Old Feb 11, 2008 | 06:31 PM
yes, used HP tuners...any suggestions?
Old Feb 11, 2008 | 06:36 PM
an0malous's Avatar
you have HP? or someone tuned it for you?
do you know what your trims are running at? sound tune related.
Old Feb 11, 2008 | 06:37 PM
Witt's Avatar
It could be your injector code throwing the fuel trims out of whack. Fix the injector lead and your P0171 might go away.
If it doesn't, retune your MAF.
Old Feb 11, 2008 | 06:40 PM
yeah unfortunately I didn't do it...I was just hoping to get a general idea of how serious this could be..thanks all for the input
Old Feb 11, 2008 | 07:13 PM
hungryhip-ccp's Avatar
dont worry you should be fine... dont drive till you get the issue resolved extended driving may cause damage. but who ever said to fix the lead to the inj is on it thats were you need to start trace the wiring from the inj and make sure theres no rodent damage or loose wires or broken inj clips hope this helps and gives a place to start...
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
