check engine light
Old Feb 22, 2010 | 05:05 PM
boricua s/c ss.'s Avatar
check engine light
does anyone have the check engine codes for the ss. i have to codes. po171 and po603. and what do they mean
Old Feb 22, 2010 | 05:12 PM
rckrz6's Avatar
P0171 Fuel Trim System Lean ECM, PCM
P0603 Control Module Long Term Memory Reset ECM, PCM
Old Feb 23, 2010 | 09:34 AM
what does that mean. that i have to reset the memory. can somebody help me please
Old Feb 23, 2010 | 09:38 AM
rico's Avatar
first one had to do with your fuel trims maybe the tune. second one idk
Old Feb 23, 2010 | 09:47 AM
so i should check my injecters
Old Feb 23, 2010 | 09:48 AM
rico's Avatar
more like the tune
Old Feb 23, 2010 | 10:01 AM
i have a stock tune. my car is completely stock. so i have to just retune it.
Old Feb 23, 2010 | 10:06 AM
Bigmacss/sc's Avatar
i have the same code. you might have an air leak around the intake or something
Old Feb 23, 2010 | 10:07 AM
randizzle's Avatar
you should take it to someone who knows what they are doing.
Old Feb 23, 2010 | 10:09 AM
umrdyldo's Avatar
Have you noticed any other symptoms?
Do you have a way to log the Long and short term fuel trim?
Have you tried reseting the system by unplugging the battery?
Old Feb 23, 2010 | 10:50 AM
i have not tried to log onto the long fuel trim. how do u do dat. also how do i check if i have a leak.
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
