Check Engine Light Question
Old Mar 23, 2007 | 04:37 PM
justin04's Avatar
Ok so the other day i hit a dog and it cracked my raditor and it leaked a little bit and the low coolant light come on and i shut the engine off and had it towed home after i got the insurance money i just ordered the parts and did it my self but i was wondering if the light will go off after a few days of drivin?
Old Mar 23, 2007 | 04:40 PM
SKDR112888's Avatar
if everything is done right it wil lgo away, but jsut diconnect the negative battery terminal and let it sit for a while to reset the cars computer,
if it comes back on you didnt do something right, and get the codes read.
you hit a dog? is it ok?
Old Mar 23, 2007 | 04:41 PM
Rusty's Avatar
the low coolant light will immediately go off if you fill the coolant to the proper level. check engine light should also go off immediately if the problem is fixed.
Old Mar 23, 2007 | 04:44 PM
SKDR112888's Avatar
Ive heard the check engine lights stay on for like 50 start ups without the problem or some weried number, i could be wrong but thats just what I thought
Old Mar 23, 2007 | 07:41 PM
cavy9psi's Avatar
check engine light will not go off right away. your best bet it so get it scanned at the dealer. who knows nothing else was damaged a sensor wire could have been clipped you never know. if it is a code that is in relation with the radiator then it can be cleared or could tell him something else isnt wrong. you could even go to a side show and have them scan the code.
Old Mar 23, 2007 | 07:44 PM
ItalianJoe1's Avatar
Might be for a sensor up front, not just the coolant level. Most codes will clear within 3 ignition cycles, if they will clear by themselves.
Old Mar 23, 2007 | 07:54 PM
cavy9psi's Avatar
i dont have a cobalt but the only sensor is the one in the radiator or sometimes in the block the thermistor which is the temp sensor and obviously the coolant level sensor which i didnt kno cobalts had but that would be on the resivior for those cars? or else where theres also the ambiant air sensor which usually is infront of the radiator and thats for the cars that have the ouside temp somehwere on the dash or the mirror for your convinance on outside tempt hat would throw a code if damaged
Old Mar 24, 2007 | 04:01 AM
justin04's Avatar
i dont think its a sensor i mean it bent the radiator a little and it leaked a little fluid i stopped and it was leakin a little the temp was like 190 so it didnt over heat i removed the front clip and took out the radiator and heat exchanger put new ones in and there isnt a sensor up front and it didnt bend them enuff to hit ne thing else wasnt a big dog it was like a beagle or something
Old Mar 24, 2007 | 12:35 PM
cavy9psi's Avatar
yea thats wierd. usually for something like that it would need to see a certian drive cycle for it go off. i mean if its still on depending on how much u drove it after u fixed it id get it scanned. if it was dripping a little it would set a code right away. it had to have been pissing to through a code. well actually then again it is a pressurized system so once a hole is made everything gets all wierd. id get it scanned. anyone you know work at a dealer??? even if its a mitsu or subaru any dealers scan tool can scan codes. and disconnecting the battery yea it will reset it but if it was me id like to know the code...for all you know it could be one of those wierd things where when that happened the check engine light came on for something else. doubt it but hey who knows.
TurboTechRacing
Oct 27, 2015 07:58 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
dieGone
Sep 23, 2015 10:20 AM
jthwjde
Sep 7, 2015 09:24 AM
