Cleaned and recalibrated the maf
Old Oct 22, 2007 | 11:46 PM
lsjwannabe's Avatar
Hit some crazy numbers on hpt, car pulls insanely hard
42.39lb/min through the maf or 321 g/sec
1.53 g/cyl peak consistently 1.45 or more wot
Old Oct 23, 2007 | 10:56 AM
Area47's Avatar
Rent me! per hour
not much in the way of part throttle timing eh?
Old Oct 23, 2007 | 10:57 AM
poppagun's Avatar
area when are you free for me to come down again.
Old Oct 23, 2007 | 11:00 AM
RedlineBrian's Avatar
I have been having trouble with my MAF recently. I figure this because my Meth isn't spraying sometimes (Snow MAF based kit) and also when logging the car we discovered that my VE graph just stays flatlined and then spikes and i show about 5-7 degrees of knock.
Do you think this is the sign of a bad MAF sensor?
Old Oct 23, 2007 | 11:02 AM
Area47's Avatar
Rent me! per hour
clean the maf and see what happens.
lsj, it still bothers me that you're hitting that high in the cells, and still running 10.10 afr.
poppa. did ya get your **** fixed?!?!
Old Oct 23, 2007 | 11:04 AM
I've tried that already. I checked the wiring for the meth. Everything looks good. I am baout to order a new MAF. Do you think the MAF is just giving out?
Old Oct 23, 2007 | 11:06 AM
Area47's Avatar
Rent me! per hour
not likely, your car would be doing dumb stuff. check the water injection box.
Old Oct 23, 2007 | 11:11 AM
The only strange thing that it has been doing is that i'll get a good amount of knock around 4k rpms under wot. And we logged the car and the VE graph is just showing a flat line not reading anything then spiking when my car knocks then flat again.
Old Oct 23, 2007 | 11:17 AM
Area47's Avatar
Rent me! per hour
these cars don't use the ve table.
if your maf blows apart. then it will use it, but not till then.
Old Oct 23, 2007 | 11:50 AM
poppagun's Avatar
ya it runs great
Old Oct 23, 2007 | 12:08 PM
06blackg85ss's Avatar
it's the VE airflow on brians car... show 2.56 lb/min..... and will randomly spike 38.xx... then drop right back down... completely flatlines
Old Oct 23, 2007 | 12:22 PM
Area47's Avatar
Rent me! per hour
got me man, my ve table is stock gm stage 2.
::shrugs::
Old Oct 23, 2007 | 12:28 PM
It's not a ve table reading, it's VE airflow.... I have no idea what's causing it.
Old Oct 24, 2007 | 12:08 AM
lsjwannabe's Avatar
hey area i got that little problm figured out almost we messed around with the car for a hour or so it is 11.6 all the way till up top were it goes to 10.8 for a split second then 12.2 so we are ironing it out
a work in progress i would say im not to much worried about it until the meth arrives...o wait i mean if i get meth
Last edited by lsjwannabe; Oct 24, 2007 at 12:08 AM. Reason: Automerged Doublepost
Old Oct 24, 2007 | 09:32 AM
SSdan's Avatar
How exactly do you 'clean' the MAF.
Old Oct 24, 2007 | 09:35 AM
lsjwannabe's Avatar
Take off your filter, look up your intake and you will see a shiny silver metal piece that is your maf spray with brake clean or something not to abbrasive and watch dirtyness go away... thats about all i did first time i cleaned it in a while and the k&n oiled it up pretty good so my idle was starting to surge at stops and my tunes were all over the place
Old Oct 24, 2007 | 12:20 PM
SSdan's Avatar
Brake clean eh'?
I know that pretty much cleans damn near everything, but something as so sensitive as the MAF?
I pulled off the filter not too long ago to clean it out, and the inside of the pipe didn't look too bad. Maybe this weekend i'll tear it apart again to clean the MAF. I doubt it'll make a difference taking it out versus leaving it in.
Old Oct 24, 2007 | 12:24 PM
Area47's Avatar
Rent me! per hour
crc has a spray designated for maf cleaning.
Old Oct 24, 2007 | 12:27 PM
yeah don't use brake clean.... get maf cleaner spray
Old Oct 24, 2007 | 01:42 PM
lsjwannabe's Avatar
i guess do what ya want just telling you what works for me
Old Oct 24, 2007 | 01:46 PM
an0malous's Avatar
electrical cleaner or crc maf cleaner. (basically the same ****)
brakeclean will work in a pinch, but the other two are better.
Old Oct 24, 2007 | 01:50 PM
6 bux at Pep Boys. MAF cleaner. Do work.
Old Oct 24, 2007 | 01:52 PM
lsjwannabe's Avatar
hmmm... what?
Old Oct 24, 2007 | 02:53 PM
Don't use brake cleaner, go spend 6 bux at pep boys on maf cleaner and do work. 22s son. Do work.
Old Oct 25, 2007 | 01:49 AM
lsjwannabe's Avatar
i works just fine half of you guys like to talk what you know works and that is the only way its not
