clooged cat?
clooged cat?
when ever i pound on the gas i get alot of smoke and most of it is black aqnd ends up on the ass end of my car would it be the cat>??
dezzie are you gm stage II? if so your gonna blow black smoke because gm has it running so rich. If your cat was clogged your car would be really quiet and fall on its face at about 3500rpms...
If your getting black smoke, thats rich, which is how the car is from the factory. GM Stage 2 is also very rich. Only thing thats going to fix that is leaning it out. GM runs it rich to keep the engine safe and to keep EGTs down. A better solution is to lean it out and run alky, you will make more power and long term you dont have near the internal dirt build up inside the engine.
If your cat is clogged you will notice much higher than normal boost pressures and possibly a code
