Clunking problem solved.
sway bar bushings
So I finally figured out a clunking noise in my suspension that's been pissing me off for about two years. Only happened when it was cold or damp outside and went away after 20 minutes of driving. Embarrassing enough it took awhile to figure it out but here's my road to victory.
End links - cabs - tc struts - passenger side strut mount - passenger side tie rod - napa axle - then finally decide to remove and drive around with my end links off which is what I should've done in the first place, replaced sway bar bushings and now the clunking is finally gone. At least my front end is pretty new and nice and tight now
