Clutch and flywheel. Any suggestions???
Old Jan 10, 2011 | 01:22 PM
07touringcoupe's Avatar
What's up people been a while but I need a clutch and flywheel. I'm not stock but I don't think I will be doing more mods to my car. If I do nothing dramatic. What clutch and flywheel should I go with thats fairly inexpensive? Should I get a lighter flywheel? Any help is appreciated
Old Jan 10, 2011 | 01:31 PM
hawlyns711's Avatar
a bunch of lsj owners use the performance upgraded one from CED, it's like $250. a lot of others use the spec stock replacement one as well but that I think was a bit more pricey. I went with the GMP one and I'm happy with my decision.
as far as a flywheel, I'm not sure about that area with the LSJ, i resurfaced my stock one and it's been fine.
Old Jan 10, 2011 | 01:33 PM
glen229's Avatar
your gonna get a range of opionons, some hate spec some love them, some hate clutchmasters some love them etc etc
when it comes to flywheels its the same, matter of opionon, some love stock some love the lightweight
i went with an exedy to start and the pedal pressure was enourmous, like a race car, now i have a spec and it feels like stock, which is nice, no other complaints about either though, im a f23 so i cant comment on the exedy or spec for the f35, though i doubt theres much difference
i would recommend the GMP upgraded clutch tho, its been known to be an exellent choice
Old Jan 10, 2011 | 01:48 PM
Where can I find a Gmp clutch? When u say upgraded you mean it could handle upto what? But yea I do want a stock feel when I drive seeing as tho my wife drives my car
Old Jan 10, 2011 | 01:50 PM
alleycat58's Avatar
GMPP clutch is the best one IMO. I have it on a low-12 second SS/SC and it holds just fine, feels just like stock for the daily commute.
Check CrateEngineDepot.com, I believe they sell it.
Old Jan 10, 2011 | 02:00 PM
Now it said something about a clutch pipe when I change my clutch. Do I need that? N is this the clutch y'all talking abt? Ecotec LSJ Clutch Upgrade Kit 19212712 - Crate Engine Depot
Old Jan 10, 2011 | 02:28 PM
hawlyns711's Avatar
^yep that's what we're talking about. it will hold a bit more power than stock from what everyone has been told (and seen). as for the clutch pipe, I'm not sure on that. I have a saturn redline, and while we do also have a clutch pipe similar to the cobalts, I didn't replace mine and it works fine. cobalt owners may suggest otherwise, and if it's cheap enough I guess why not.
Old Jan 10, 2011 | 02:51 PM
Ok now the flywheel. Is that the 1 on that site also?
Old Jan 10, 2011 | 03:12 PM
hawlyns711's Avatar
I don't believe gm makes an upgraded flywheel, only the clutch/pressure plate combo.
Old Jan 10, 2011 | 03:15 PM
scotch89's Avatar
GM cluch is what i have, its been good. make sure you slave cylinder dosent poop the bed when you replace the clutch. thats what happened to me and it sucks
Old Jan 10, 2011 | 03:18 PM
Ok cool. It's it best to get that flywheel on crate engine depot? Is that a stock flywheel? Or should I get a light weight joint?
Old Jan 10, 2011 | 04:33 PM
alleycat58's Avatar
Stock flywheel is fine, I would stay away from the lightweight ones.
Old Jan 10, 2011 | 04:49 PM
Ok so is a new 1 good or should I get the old 1 re surfaced?
Old Jan 10, 2011 | 09:05 PM
Anyone?
Old Jan 11, 2011 | 07:00 AM
xxxxsh4d0wxxxx's Avatar
Elaborate?
Old Jan 11, 2011 | 07:13 AM
Pls do
Old Jan 11, 2011 | 08:46 AM
Littlegoose's Avatar
I've seen complaints on other forums about lightweight flywheels, especially for daily drivers, because of the quick wind down. You don't get to coast like you used to because of less rotating mass, so you'll have to stay on the gas longer. You might think, oh thats not that bad, but if you're like me, you coast a lot. I could see how it would get annoying.
I've also heard that you don't get the inertia you would with a heavier flywheel to really launch the car from a dig. Granted, this was on a 3000GT forum, they were talking about AWD, so this probably doesn't apply as much to us but still.
Old Jan 11, 2011 | 10:13 AM
So a stocker would work best that's what you are saying? And is the 1 on crate engine depot is that a stocker?
Old Jan 11, 2011 | 10:19 AM
hawlyns711's Avatar
the one on CED is stock. stock is the better option IMHO.
Old Jan 11, 2011 | 10:34 AM
Also, fyi I just found this while browsing RF which goes along with what I was saying:
http://www.ionforums.com/forums/ion-...ghtweight.html
RAY321's Avatar
Keep the stock flywheel if going with the GM upgraded clutch just have it cut by a machine shop it wouldn't be a bad idea to have the flywheel and pressure plate balanced together. Also you will have to replace the flywheel bolts just an FYI before you order the new clutch.
Old Jan 11, 2011 | 11:00 AM
Thanks for all the help. But doesn't the bolts come with the kit? Both clutch and flywheel?
Old Jan 11, 2011 | 11:31 AM
RAY321's Avatar
If you are getting the GM upgraded clutch then no it does not. Only comes with Clutch disk, pressure plate and throw out bearing.Ecotec LSJ Clutch Upgrade Kit 19212712 - Crate Engine Depot
Old Jan 11, 2011 | 12:18 PM
So I need bolts both for the flywheel and clutch kit!
Old Jan 11, 2011 | 01:42 PM
RAY321's Avatar
Only for the flywheel, if you remove it.
