Clutch gone, What to do?
Old 12-03-2006, 09:13 AM
FLCobalt's Avatar
My clutch is destroyed. I mean it still works but it is sooooo hard to push down and it has to be mashed all the way to the ground. I have about 13000 on the car so i know ive made it farther then alot of us.
Part of my problem was i taught a few people how to drive on my car, and let a few females drive my car on more then one occassion.
I doubt taking it to the dealer will have it fixed under warranty. I wish....
But any ways whats a good aftermarket clutch, there was a gap in time when i wasnt really reading these forums ( due to lack of funds and i would get depressed seeing everyone's car getting stuff and mine staying the same) And now if seen some comments about the spec clutch being "no good" some elightenment on this would be greatly appreciated. And if we arent able to use the spec clutch what after market options do I/we have?
Without a new clutch it doesnt even make sense to add any more power adders to the vehicle so i really need to get this taken car of. If possible does anyone know a way the dealer can fix it ( i know it would just go out again but atleast it would be a temp. fix) Or is anyone selling an aftermarket one.
Also if some of the more technical inclined guys could shed light on what could happen if i continue to drive my car with this worn out clutch, what risks am i running.
Thanks in advance.
Old 12-03-2006, 09:16 AM
FLCobalt's Avatar
excuse the poor grammar and stuff in the OP, its 9am here and im at work and im beat.
AIG Auto Insurance Overtime Ftw.
Old 12-03-2006, 11:17 AM
Coblt ss super's Avatar
yeah my clutch is slipping at 8600, being my first manual car and did a stupid burnout the other day which i shouldnt have, i might need a new clutch, the clutch is jsut slipping very little noting major, whats the best aftermarket clutch out there?
Old 12-03-2006, 11:25 AM
2K5SS/SC?'s Avatar
Exedy clutch and flywheel kit is what I would buy. I know someone on here has to have on installed by now. Clutchmasters worked the kinks out of their setup finally after three revisions and that is what I'm using now. Centerforce may also have released the dual friction setup they were testing quite awhile ago. I would stay away from Spec though.
Old 12-03-2006, 11:27 AM
alrighty i may go with a clutchmasters then, because somone else also told me stay away from spec lol
Old 12-03-2006, 11:40 AM
Moderator Alumni
zinner's Avatar
25k and mine is still fine. Knock on wood.
Old 12-03-2006, 11:49 AM
distillion's Avatar
15000km at it feels the same as if did on day one.(spirited driving)
Never had any females drive my car.
shift at 3k or higher.
Old 12-03-2006, 11:54 AM
Moderator Alumni
zinner's Avatar
Female drivers hurt the clutch ? Come on guys lets give girls a little credit
Old 12-03-2006, 12:05 PM
yellowcobaltss05's Avatar
get a new one lol I would try the clutchmasters. I have 27,000 miles and my stock clutch is fine
Old 12-03-2006, 01:10 PM
Shortbus's Avatar
Exedy clutch and flywheel hands down.
Old 12-03-2006, 01:20 PM
NGalaxyTimmyo's Avatar
Whats so bad about the spec? I have people around here that swear by it
Old 12-03-2006, 02:34 PM
tcolli17's Avatar
Is the clutch slipping really bad ( clutch plate worn out= new clutch), or is it just really hard to push down ( either pressure plate problem or hydraluic system problem). If it is a hydraluic problem that needs to be fixed and buying a clutch won't help. Having a worn out clutch that is slipping should not have any affect on the feel of the clutch pedal. From the way you described it, it sounds like you have other problems.
Old 12-03-2006, 02:37 PM
JCswoosher2's Avatar
Im experiencing slippage in my Spec stage 2+ and i have 5,000 miles on it. cant be good
Old 12-03-2006, 02:45 PM
tcolli17's Avatar
This sounds like the hydraulic pin that pushes on your clutch lever is out of place. Check your fluid level also.
Old 12-03-2006, 03:02 PM
2K5SS/SC?'s Avatar
tcolli,
What hydraulic pin are you taking about? Could you post a pic on the ss.net so I can see it?
Old 12-03-2006, 03:15 PM
rallyracer's Avatar
Does Exedy make a good clutch set up that works well with daily driving, if so which one???
Old 12-03-2006, 03:44 PM
Shortbus's Avatar
Check out dezod's website, exedy makes the best clutch and flywheel out imo for the cobalt, it is used in the cobalt time attack car. I had spec on my car and took it out.
Old 12-03-2006, 08:09 PM
tcolli17's Avatar
Originally Posted by 2K5SS/SC?
tcolli,
I went out to my car to see how the clutch was engaged and disengaged, but I couldnot see from the top. In another car that I had, the place I had it (similar symptons) was where your hydraulic system would engage the clutch. This is on the bell housing where there was a lever that was connected to the throw out berring on the pressure plate that released the pressure on the clutch, disengagng the clutch. I will do a serch but you should get in contact with some people that have replaced their clutch on the cobalt to see if they run the same setup and where it is.
Old 12-03-2006, 08:41 PM
tcolli17's Avatar
Originally Posted by WopOnTour
Dan
Check the clip that retains the apply rod into the clutch pedal upright.
I've seen them break and/or loose detent/retention allowing the shaft to engage too far into the pedal, reducing master cyl travel/stroke
It's a bit of a PITA to get access to though...
HTH
Wop
pm him with your problem, he seems like he knows what i am talking about and has taken out our kind of transmission.
Old 12-03-2006, 08:43 PM
tcolli17's Avatar
they said the system is under the pcm tray and fusebox.
Old 12-03-2006, 08:46 PM
p7x
p7x's Avatar
Exedy!.................BTW 48,000 kms clutch is fine but on my 2nd master cylinder.
Old 12-03-2006, 09:53 PM
FLCobalt's Avatar
im not technically inclined at all. is there a simple version? Demod and take to gm?
Old 12-03-2006, 10:24 PM
tcolli17's Avatar
Where in fla are you. I would try to talk to someone that is technically inclined and maybee take it to a transmission shop before GM. They should be able to tell you what is wrong. The only reason why you would need to get a clutch is if it is slipping. To get a good aftermarket clutch you are looking at 550-600 just for the clutch and not the install. I would guess around 300 for the install. If you do need a clutch the transmission shop would probably do it cheeper than GM. But hopefully it is something simple.
Old 12-03-2006, 11:37 PM
bdwarr6's Avatar
i have a spec 2+ 2.6 60lbers and a decent tune with new piston i just hit about 500 miles of driving the other day i dropped it at 4k and no problems
and just to keep people from sayying i abuse my car i wanted to test the ****** i would never do that without reason
Old 12-03-2006, 11:57 PM
2K5SS/SC?'s Avatar
tcolli,
I've replaced the clutch three times due to the CM fiasco. I believe the linkage or pin you speak of would be inside the car under the dash from your description. Under the fuse box is just the hydraulic line that runs from the resivour to the aluminum block on the trans, and then to the slave cylinder. There is a retaining clip in that, but no pin.
Fl,
My clutch went at 7000-8000 miles. The stock setup blows, and obviously you have figured that out. I would get the Exedy kit and be done with it all. It will still be streetable as it's not a 4-puck, pressure will increase some, and you will have to relearn it's engagement point. These changes were more than welcome in my car with my CM FX300because they make driving it feel so much better. If Exedy had their kit out when I needed a clutch, I would have bought it on the spot no questions asked.
Quick Reply: Clutch gone, What to do?
