Clutch Problems
Old Oct 3, 2013 | 02:38 PM
slambaltss's Avatar
Clutch Problems
I just got my SS/SC about a month ago and my clutch is going out pretty bad. I can still accelerate out of first and second if i dont push the throttle too much but if i have to speed up in a hurry for any reason its not going to happen.
At 20 MPH in 5th gear i can push the throttle and it will just fly up in the RPMs and not go anywhere...obviously the clutch is slipping.
I'm not too knowledgeable when it comes to clutches hence why i am asking this question.
Exactly what parts do i need? Clutch, Pressure Plate or both?
Thanks in advance!
Old Oct 3, 2013 | 02:45 PM
That Cobalt LT Guy's Avatar
You need a clutch disk, pressure plate and a throw out bearing. You replace all at once when you do a clutch.
Old Oct 3, 2013 | 02:47 PM
andrewcarr1993's Avatar
Well first of all when you floor it, don't do it in a high gear. Second of all GMPP clutch is what you want.
Ecotec LSJ Clutch Upgrade Kit 19212712
Old Oct 8, 2013 | 10:37 PM
09CobaltSS1's Avatar
^^ This, plus new flywheel (or resurface your old one), flywheel bolts (they're torque to yield, so they're not reusable), pressure plate bolts (cheap insurance), clutch bearing mounting bolts (they're very easy to strip if you aren't careful however not 100% necessary), clutch pipe, 2 bottles of trans fluid and an alignment tool.
Old Oct 13, 2013 | 04:18 AM
bLu04dd's Avatar
I just got the GMPP kit myself for my LSJ swapped 04 Cavalier. I bled it but it still feels pretty light when depressing the pedal...have you installed it yet? My old stage 2+ 6puck clutch I had on my original engine/tranny (F23) set up felt a little stiffer. I did the reverse bleed and it filled up the reservoir pretty quickly..so Im hoping all the air is out of the line. Something doesn't feel right but Im comparing it to a stage2 6 puck clutch..so yeah.
Is this clutch supposed to be pretty light? And you cant beat the price for the upgrade kit on CED compared to even a stock replacement!
Old Oct 13, 2013 | 06:01 AM
footballplaya3k's Avatar
The GMPP is very light, just how it is. Works great though.
Old Oct 13, 2013 | 06:03 PM
mrbelvedere's Avatar
move your post to problems and service or driveline
Old Oct 14, 2013 | 06:35 AM
BlackyK's Avatar
In the mean time, bleed the clutch fluid to put a little life back into it until you can replace it. I've bled mine about 5 times in 100k miles and its still pretty solid considering the pounding its taken in 6 years.
Old Oct 14, 2013 | 11:51 AM
bleeding the clutch wont help
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
