Clutch recommendations?
Old Dec 3, 2009 | 06:00 PM
zooyrk171's Avatar
So i was set on buying the ott performance stage 2 pulley kit on black friday and right before i ordered it my dealership who is putting in my new engine(warranty due to cracked block between cylinders 2 & 3) called and asked me if id like to put a new clutch in before they put it back together because supposedly it was worn down so bad that it was only going to last a couple days.Now i never realized this because i had never even experienced a single clutch slip or any weird symptoms. I told them to just put the stock clutch back in and that id take care of it so with my ott stage 2 dreams put on hold until Christmas what clutches would you recommend from personal experience that are not pricey that also will go well with my future 2.8 setup?
Old Dec 3, 2009 | 07:27 PM
qwikredline's Avatar
gmpd upgrade clutch...
Old Dec 3, 2009 | 07:38 PM
~Mike~'s Avatar
x2^^ You really don't need much more than the upgrade from GM. The OTT stage kit isn't going to put your power high enough to spend big $$ on a bigger clutch
Old Dec 3, 2009 | 08:07 PM
selfinfliction's Avatar
get the act kit.. either street or sprung puck. act makes the best medium market clutches hands down
Old Dec 3, 2009 | 09:58 PM
zooyrk171's Avatar
I completely forgot about the gmpp upgrade clutch thanks for the recommendation i found them on crateenginedepot.com for only 259 so im most likely going to make my order tomorrow on pay day.It should be fine because im not planning on doing any further mods the only thing ill be running is the 2.8 kit,my zzp 3" intake, and a heat exchanger
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
