Code Reader Not Working?
Old Oct 25, 2005 | 07:16 PM
turboeco's Avatar
Went to Auto Zone after work today. Car had HORRIBLE cold start up after work, rpms were everywhere, blowing black smoke. Smoothed out after a few seconds, then I drove home.
Vacuum was acting a little funny while at a red light, jumping between 15-18psi, car shut off. Started up drove home and shut it off.
Still wondering what was up, I started it back up and drove towards town. Thats when the CEL came on.
Took it to AutoZone and their OBD-II scanner wouldn't even turn on when plugged in. Guy tried it on the Ford Focus next to me, and it powered right up!
Funny thing is, they read a code for me before at the same shop. Why wouldn't it work now?
Is there a particular code reader I need? Please let me know.
THANKS!
-Travis
Old Oct 25, 2005 | 11:36 PM
spooler's Avatar
sounds like the computer went poof
Old Oct 25, 2005 | 11:39 PM
MarcS's Avatar
The Stig
There is a TSB on this issue. I have trouble with cold starts as well. This is an issue with the PCM. A reflash should take care of the problem.
Go to: http://calid.gm.com
Enter in your VIN for PCM calibration info.
Old Oct 26, 2005 | 12:25 AM
zinner's Avatar
Moderator Alumni
Was the car on when they plugged in the scanner?
Old Oct 26, 2005 | 06:52 AM
turboeco's Avatar
Key was turned forward to ON position, car wasn't started.
I'm wondering why it wouldn't power on, especially since they used it on my SS before?
Do I need a CAN OBDII scanner, or is there DEF something wrong with my scanner port?
Thanks guys.
Old Oct 26, 2005 | 08:46 AM
R33P3R007's Avatar
360 L337 User
How does this work?
Old Oct 26, 2005 | 09:17 AM
Chevypowered's Avatar
That’s pretty sweet. So it shows you what your car currently has with the green dot? Just got mine in for the cold start thing yesterday, we'll see if it works shortly. Thanks for the great link, very useful.
Old Oct 26, 2005 | 10:10 AM
WickedSS2005's Avatar
Um, it's been doing the "Getting Calibration Info" for about 10 min now, is that normal for the site?
Old Oct 26, 2005 | 11:30 AM
patathSS's Avatar
Hey Wicked, If you have a browser with pop up blocker (Firefox), you might have to open the pop up. I did and it redirected me to the calibration info. Hope this helps
Old Oct 26, 2005 | 12:45 PM
MarcS's Avatar
The Stig
No, it should be pretty quick.
Some people have trouble with it, what browser are you using?
Old Oct 26, 2005 | 03:37 PM
R33P3R007's Avatar
360 L337 User
yup I had that problem just allow popups from that site
Old Oct 26, 2005 | 05:11 PM
turboeco's Avatar
Car did it again this morning, it was REALLY cold.
Car would start then get jumpy idle, sound like **** then shut off. Did it to me 3 times, until it would finally start and run.
After work today, started up fine. Only problem is CEL, and a hiccup @ WOT in any gear.
This is killing me, been thinking about it all day. Wondering what suddenly happened? It was running incredible.
Fujita was on for 4days ran perfect. Then Monday night I took the CAI apart and repositioned it. Tues. morning drove literally 3mins. to work, ran fine. It was after work(raining all day, super cold) that I started it up and it sounded like **** and wanted to shut off. CEL followed minutes later.
Tried to get code read, but OBD-II scanner at AutoZone wouldn't power up when plugged in. Worked on the Focus next to me, but not mine. It worked last time, any idea why it wouldn't power up this time? Do you need to have the engine running on this car?
Old Oct 26, 2005 | 05:22 PM
NJBLUESS's Avatar
Check all your fuses. You most likely blew an ACC or LTR fuse. The diagnostic connector powers up from one of them. There are two fuse blocks in the car. The owners manual shows location and fuse description.
Old Oct 26, 2005 | 05:23 PM
turboeco's Avatar
Also according to that CALIBRATION TABLE after giving my VIN number... I have the most up to date versions of everything, according to the green dot.
If I already have the Cold Start fix, what the hell could it be?
Old Oct 26, 2005 | 06:05 PM
Maverick's Avatar
Just fyi, I took my car to autozone and they read a lean code I had. Turned the key to on position without starting the car. So no, you don't have to start the car to read the codes.
Old Oct 26, 2005 | 06:32 PM
zinner's Avatar
Moderator Alumni
Thanks guys.
I would have tried it with the car running.
All you need is an OBDII scanner, there is no need for CAN for just getting the DTCs.
Old Oct 26, 2005 | 06:44 PM
turboeco's Avatar
Ok listen to this.
Checked Fuses, lighter fuse was blown. Took over to same AutoZone. This time the OBD-II scanner would say Linking Please Wait, but NEVER connect.
So now its getting power but the scanner won't link up!?!
Let me know if you got any suggestions for this one, Thanks for all the help!
Old Oct 26, 2005 | 06:48 PM
turboeco's Avatar
I'd rather not take it to a dealer, but looks like I may have to.
I have no f'ing clue whats wrong, since I can't get the code read.
Old Oct 26, 2005 | 07:19 PM
NJBLUESS's Avatar
Check all other fuses(if you didn't already). Especially module fuses, PCM,ECM, etc. You need to establish communications first and retreive codes. Also check for anything that may have become disconnected. By the way it is running your PCM has no control over the engine.
Old Oct 27, 2005 | 12:05 AM
I still can't get the site to show. I use Internet Explorer. and I disabled Norton antivirus and Internet Security and allowed pop-ups....gr
Old Jan 18, 2007 | 03:26 PM
SSROMER's Avatar
THANKS!
-Travis
im having the same problem i think it is the fuse but you said you replaced it see if anyone you know has hp tunners and plug it in it should work im not sure thow
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
DocSvensk
Sep 27, 2015 02:24 PM
jmelton327
Sep 26, 2015 10:04 PM
OrangeCoba
Sep 25, 2015 06:06 PM
