Cold air intakes
Old Apr 27, 2008 | 11:35 AM
buter's Avatar
Exclamation Cold air intakes
I just put a cold air intake on my 07 cobalt ss/sc and my check engine light keeps going on and off with the same codes. Does anyone else have this problem and have any solutions? Thank you
Old Apr 27, 2008 | 11:36 AM
Routs's Avatar
Did you unplug the battery for 10 minutes after installing it?
Old Apr 27, 2008 | 11:42 AM
originaladrian's Avatar
scan the code, if its a lean code dont worry abt it, its normal. ither clear ur codes or dissconect ur battery for a while after every power mod.
Old Apr 27, 2008 | 11:59 AM
AJH79's Avatar
Mine did the same after I installed my intake... I brought it in to the dealership 3 times and they were starting to get annoyed with me. I don't know what they did but it has now been 10 months and it's never came on again.
Doesn't the battery have to be unplugged during installation anyways??
Old Sep 19, 2011 | 12:01 AM
demon2701's Avatar
Hey guys,
I just put in a K&N air filter in the airbox of my cobalt ss/sc. I read somewhere that some people actually left the bottom off or drilled holes in the airbox for more airflow. Any of this a good idea? I mean, a full intake would be best no?
Old Sep 19, 2011 | 12:46 AM
b00sted06ss's Avatar
When I put my rebel auto works intake on I never got any cel, and I've had it on for over a year
Old Sep 19, 2011 | 01:20 AM
Bluelightning's Avatar
Got Bewst?
Originally Posted by demon2701
Hey guys,
Yes it's called the "airbox mod". It's a cheap mans cold air intake haha. I ran my airbox with no bottom for over a year before buying an intake. A full intake is best but taking the bottom off the airbox is a cheap alternative.
Old Sep 19, 2011 | 01:28 AM
I thought about doing this mod lol, did you notice any hp difference?
Old Sep 19, 2011 | 07:18 AM
Staged07SS's Avatar
Administrator
Administrator
Hey guys,
That's my current setup....
I used to have an Injen intake, but found my production intake with K&N & modified airbox actually flows more air.
Both tests performed on the same day, same temps (9/16/11, 68*F):
33.95 lbs/min of air with the Injen.
35.41 lbs/min of air with the modded production intake.
These cars come with a cold air intake from the factory that flows very well. I've finally learned that after testing numerous intakes (XTC, Rebel, AEM, Injen), and talking with John Powell. I'm also in the process of building my engine to Time Attack specs, and that car ran the production intake, modded airbox, and K&N filter.
Old Sep 19, 2011 | 06:11 PM
Got Bewst?
From the research I did before buying an intake it seemed noone had anything good to say about the Injen intake haha. But thats pretty crazy that the stock airbox flows better than the Injen when you see restrictions like this in the stock airbox lol.
Old Sep 19, 2011 | 06:21 PM
Staged07SS's Avatar
Administrator
Administrator
That really does not restrict any flow.
It turns oblong at the bend (see photo of my intake). It gets wider to compensate for going narrower at the bend to reduce restriction. If you were to bend the tube into a cylindrical shape it would be pretty much the same diameter as the rest of the piping (I tried this on an extra intake tube I had laying around). AEM engineers tested a full cold air intake, and saw no further gains by replacing the upper portion of piping. The Time Attack car made almost 400whp (nitrous of course), and retained the factory intake piping.
I've tested many intakes on my car. None of them made any difference other than some changes in the whine of the blower. That's it. The restriction in the stock intake system is the paper filter. Replace that with a high flow unit, and you are set to go.
Old Sep 19, 2011 | 06:38 PM
Got Bewst?
Good info! I got my ZZP intake for dirt cheap so thats why I got it haha.
Old Sep 19, 2011 | 06:48 PM
Staged07SS's Avatar
Administrator
Administrator
Hey man, I don't blame ya.
The ZZP intake is def good quality.
Old Sep 19, 2011 | 06:59 PM
sjc0013's Avatar
Window Licker
Wow, that's crazy! Good info staged! How'd you measure the air flow?
Old Sep 19, 2011 | 07:04 PM
Got Bewst?
I thought remember ULWiz (who I bought my intake from) getting some really good gains at the track after he installed his CAI. But maybe he installed something else at the time too that I can't remember.
Old Sep 19, 2011 | 07:08 PM
Staged07SS's Avatar
Administrator
Administrator
Thanks!
I measured the air flow on my interceptor.
I record all my logs in a little note book. I've been meaning to make an excel spread sheet to show some comparisons, but have been to busy. One day I will.
Nah.
He got retuned and such. He always had an intake. He just went from the Injen to ZZP.
Last edited by Staged07SS; Sep 19, 2011 at 07:18 PM. Reason: Automerged Doublepost
Old Sep 19, 2011 | 07:52 PM
Boosted05's Avatar
i'm ditching my K&N for a ZZP CAI soon, all I can say when looking at a CAI is get one that does not sit on the damn bottom of the fenderwell..... I donated 1 motor to that little problem already....
Old Sep 19, 2011 | 07:55 PM
Got Bewst?
Nah.
So you've never retuned your car after installing your CAI?
Old Sep 19, 2011 | 09:03 PM
Staged07SS's Avatar
Administrator
Administrator
I am tuned for the intake on my car right now.
I have always been tuned.
I said ULWiz retuned, but not just for an intake. He went from GMS2 to GMS3 then had BYT tune him further.
Old Sep 19, 2011 | 09:50 PM
Jmc007's Avatar
Good info. Some the CAI (like K&N if I am not mistaken and please correct me if I am wrong) have a 2.5" dia. tube which is smaller than the stock tube diameter (at least when the stock intake is measured at the MAF location at 2.875" inside diameter). Another test that can be done is to measure the supercharger inlet pressure (vaccuum) with the Aeroforce Interceptor gauge; it will indicate about your intake & filter restriction. On my car (at 3500 ft altitude) the stock airbox with lower lid removed and K&N filter high flow filter is "only" restrictive for about 0.2 to 0.4 PSI at WOT (when boosting 12.5 PSI after supercharger) but we should do the same test for the full 3" dia. intakes to see if this vaccuum can be brought closer to zero.
Last edited by Jmc007; Sep 19, 2011 at 09:58 PM. Reason: Changed "pre-supercharger" to "supercharger inlet".
Old Sep 19, 2011 | 10:10 PM
Staged07SS's Avatar
Administrator
Administrator
Stock is 3" (prob 2.9xx" something with digital calipers) at the MAF provision.
My Injen was 2.625" I.D. (2.75" O.D.) for most of the piping & 2.875" I.D. at the MAF provision.
I believe the K&N intake is around the same size as the Injen.
I ran that test as well man. I saw 0.1-0.2 PSI at WOT from 6900-7250rpm (hardly any restriction). Good test to perform.
I should have ran this test with my Injen intake, and all the other intakes I owned back in the day.
Old Sep 19, 2011 | 11:12 PM
demon2701's Avatar
You had no problems with leaving the bottom off the airbox?? Can the filter hold up without the bottom? If so, i'm going to try it. Does it make any difference for the sound or power?
Old Sep 20, 2011 | 12:09 AM
Thats where my rebel intake sits, but never had any problems with it!
Old Sep 20, 2011 | 12:18 AM
Got Bewst?
Nope you will never have a problem as long as the filter is secured good. Charger whine is definitely louder. More air means more power haha. Clicky the linky.
https://www.cobaltss.net/forums/how-...fication-3890/
Old Sep 20, 2011 | 07:06 AM
Staged07SS's Avatar
Administrator
Administrator
I still have the bottom lid attached on mine. I drilled a series of 7/8" holes in the bottom portion, along with a 1" & 3/4" hole on the sides of the bottom lid. I will post photos later if you need to see what it looks like.
It is nice and clean looking.
