coolant in my intake manifold. HELP.
it ran long enough to warm up and expand that gasket... lol! its all good tho. i have everything ordered to fix it. depending on when i get it all ill have it on the road in a few days. hopefully by the weekend of not sooner
might as well upgrade when you got the head apart!
but i just talked to my dealer about getting the laminova o rings and the endplate seal... yea $202 with my buddies discount... friggin insane. they said thats w/ out the cores too... im pissed.
not to jack this thread but while we are on coolant issues.. my 99 grand am 3.4L winter beater has the infamous dexcool ate the intake gasket problem... air somehow charges my cooling system and makes it **** out the overflow tube til the coolant burbles and the car overheats... anyone have a quick fix idea for this other then changing the intake gasket or junking the car? lol already ran leakstop in the coolant and am not flushing the system because the dirt may be what's holding things together..
Yes 89 inch lbs as someone else mentioned.
Yes, the seals are killer expensive new. When I did my SC build I got a used intake and the seals were wrecked. Since I am a dealer we had an o-ring kit in house that had the proper size and thickness of seals for the cores. You have to look around and get the correct size and thickness... but I wouldn't put back together without new. So far so good on my setup.
Last edited by Gene Culley; Nov 25, 2009 at 09:29 PM. Reason: Automerged Doublepost
help
but im gettingengine coolant in my intake manfiold so how does that happen and i know it is engine coolant cuz i put the uv dye in the engine coolant and not the h/e and the intake ports on the head and manfiol are glowing frome dye so what gives
well i did re use that seal... i wonder if thats the problem... so do i replace the o rings for the cores or do i replace the seal that goes all the way around the endplate or both?
i used ZZPs hose routing diagram. but again i dunno if i have the cores correct. everyone says sumthin different
OrangeCoba
Sep 25, 2015 06:06 PM
