Coolant Temp
Old Sep 1, 2009 | 12:07 PM
ssua's Avatar
Coolant Temp
Hi there everyone.
So I was just checking out my Coolant Temp and I just want to make sure that it's normal.
The temp is 207F with the AC on. And 194 without. Oh yeah it's a Cobalt SS / SC.
Let me know thanks.
Old Sep 1, 2009 | 12:11 PM
Black05's Avatar
Normally, my car will run at 185-187 on the highway or moving, 194-210 idling in traffic, and 190-200 with ac on. The numbers you posted are perfectly normal, no irregularities.
Old Sep 1, 2009 | 12:14 PM
ssua's Avatar
Alright man thank's allot... Happy to hear that
Old Sep 1, 2009 | 06:43 PM
drew1991sf's Avatar
is it stock? i have stu mod and h/e
i cruise at 171-176 with no ac. and idle with no ac at 181-186, unless im at a drive thru which it gets up to 207 before my fans turn on to cool it down.
Old Sep 1, 2009 | 06:49 PM
ddsscobalt's Avatar
when i crusiing with gms2 and ottp h/e im at 181.. idle it will go up to 210... idk with ac on cuz i never really used it our summer never got that hot
Old Sep 1, 2009 | 06:51 PM
Pyros777's Avatar
fyi stu mod, h/e, killer chiller, ice packs on your supercharger, wont affect your engine coolant temps. different circuit..
Old Sep 1, 2009 | 08:00 PM
Gene Culley's Avatar
Talking
Yeah, exactly. lol. It is not the same.
Old Sep 29, 2009 | 12:11 AM
Omnigear's Avatar
bump for this my temps is gettin up 2 220deg , i have to turn on the a/c for the temps to go down.
thinking of clogged cat?
Old Sep 29, 2009 | 11:36 AM
damien's Avatar
Normal
Old Sep 29, 2009 | 02:24 PM
ddsscobalt's Avatar
I have a question than, since I was just informed about me being an idiot. Since the H/e doesnt affect the coolant temps, if i remember correctly it affects the IAT temps??
How would I know if its working right If i dont have a scan gauge?
Old Sep 29, 2009 | 03:27 PM
Karlen89's Avatar
You won't.
Old Sep 29, 2009 | 03:28 PM
ShortStack's Avatar
^^ Know what isnt working right?
The heat exchanger pump is the thing that fails.. you can check this by checking the cap of the filler neck...
Old Sep 29, 2009 | 04:31 PM
Omnigear's Avatar
so at what coolant temp should i be alarmed?
it goes as high as 220
Old Sep 29, 2009 | 05:04 PM
Pyros777's Avatar
Under what conditions does this happen?
I've seen mine go as high as 224 in rush hour traffic going super slow.
Old Sep 29, 2009 | 05:09 PM
Johnboy12358's Avatar
Mine usually doesnt go over 200, if it does, I make sure the A/C is on and it comes back down. If I am sitting still at a light, with AC on, it wont go over 190 or 192, cruising, 180 solid. It is as low at 175 sometimes.
Old Sep 29, 2009 | 06:00 PM
ddsscobalt's Avatar
what I mean is: I got the H/E as a Cooling mod for when I get the OTTP1 kit. Right now im GMS2 with a 2.9 and injen intake... Since the H/E is a Cooling mod, is there any way to tell if its doing its job?
Old Sep 29, 2009 | 06:42 PM
Omnigear's Avatar
normal driving conditions is when it happens. i guess i just now started payin attention 2 it. but what is the temp b to get worried240?
Old Sep 29, 2009 | 06:56 PM
06cobalt racer's Avatar
to see the temps on the supercharger side. i.e. iat temps. you will have to get a scan gauge like the interceptor. there is really no other way to check it
brandon04
Oct 21, 2015 07:04 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
riceburner
Sep 26, 2015 12:57 AM
