Coolant temps phenolic spacer
Old May 5, 2012 | 09:47 AM
SaberD's Avatar
Given that the intake manifold acts as somewhat of a heat sink for the cylinder head, I'm wondering how much additional heat the head sees from adding a phenolic spacer. I'm sure the cooling system would take care of the temps under normal driving. Perhaps it might be a good idea to get an upgraded radiator in combination with this mod on an otherwise stock vehicle if you're going to take it to a road course. Any thoughts?
Old May 5, 2012 | 12:04 PM
nhanson's Avatar
I honestly think there would be no issue. 2.2 and 2.4 guys have plastic intake manifolds so i would think they would act the same.
My coolant temps are actually higher since ive been SCed
Old May 5, 2012 | 12:12 PM
lots of good info in here, dont quote me but i think it was around 5-10 degrees which is awesome, also it stays a lot cooler when say ur in the staging lanes sitting in traffic etc. quicker recovery after pulls. good upgrade that i cant wait to get
https://www.cobaltss.net/forums/2-0l...ry-lsj-259817/
Old May 5, 2012 | 12:13 PM
BankerBalt's Avatar
he's stock SC, not 2.2/2.4. on an NA cobalt, intake temps aren't nearly as high because air isn't being forced into the engine, the engine is sucking in it's own air without any outside help... spacer would lower IAT's, not coolant temps. and if they did, wouldn't be much. if you want lower coolant temps, get a dual pass endplate
Old May 5, 2012 | 12:19 PM
willdrew's Avatar
Dual pass is for your iats also not your engine coolant temp
nhanson's Avatar
You guys are missing his question. Hes wondering how hotter the head gets from adding the spacer. Not how much heat it takes away.
Old May 5, 2012 | 12:39 PM
Sharkey's Avatar
i cant really see it being an issue. maybe in 110 degree weather and going around a road coarse you would see a difference.
Old May 5, 2012 | 01:04 PM
mrbelvedere's Avatar
the heat is created inside the blower not from forcing the air but from compressing it inside the housing
the head may see a couple of degrees more but nothing even close to a danger level a bigger radiator isent needed either the stocker is more then sufficant
did you change your thermostat
Last edited by mrbelvedere; May 5, 2012 at 01:05 PM. Reason: Automerged Doublepost
Old May 5, 2012 | 01:08 PM
zerosk8ter83's Avatar
The only issue im going to see is how the hell am I gonna have room for the blower on my 2.2 auto
nhanson's Avatar
Never touched it. 72k miles.
Old May 5, 2012 | 01:09 PM
nhanson's Avatar
It fits. Just need to notch the rad support where the pulley hits.
Old May 5, 2012 | 02:25 PM
put an lsj thermo in it
Old May 5, 2012 | 03:18 PM
nhanson's Avatar
Its cooler im assuming? how much?
Old May 5, 2012 | 06:04 PM
180
Old May 6, 2012 | 10:16 PM
bluebalt07's Avatar
Mine runs the same temperature as it did when I was NA, just seems to warm up a little faster after start up.
Old May 7, 2012 | 08:00 AM
SaberD's Avatar
Thanks for the info guys. Looks like I'll be doing this mod after all.
Old May 7, 2012 | 08:31 AM
hhrfreek's Avatar
the 2.4l stat is 180 too. My coolant temps went up as well after I installed the SC.
Old May 7, 2012 | 02:29 PM
noorj's Avatar
does anyone know if the lsj thermostat will work in a le5?
brandon04
Oct 21, 2015 07:04 AM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
jmelton327
Sep 26, 2015 10:04 PM
riceburner
Sep 26, 2015 12:57 AM
