Cooler Thermostat for the Balt?
Old Jun 20, 2006 | 08:45 AM
CTCOBALTSSS's Avatar
Question Cooler Thermostat for the Balt?
These ss/sc's run hot in traffic. I know chevys are notorious for this because I have had a few. Does anyone know of a 10 degree or 20 degree colder thermostat? Ours must be a 190 degree or something right? Maybe a 180 degree would work nicely.
Old Jun 20, 2006 | 09:10 AM
silverSS's Avatar
ours is 180
Old Jun 20, 2006 | 09:14 AM
Chevypowered's Avatar
You need to get the HPtuner and set the fans to a lower temp., that would help a lot since they don't comeone til 220 or so. I believe you can set the fans as low as 180.
Old Jun 20, 2006 | 09:28 AM
WOW, ours is 180 already? Setting the fans to come on earlier is a good idea but not everyone has HPTuners. For those that don't have HPTuners, is there a cooler thermostat for our car?
Old Jun 20, 2006 | 09:29 AM
BullDog71ss's Avatar
Do not put a different thermostat on your balt. It runs fine the way it does. You could do more harm than good as it's setup for the stock one. They are also setup to run hot like they do, there's nothing wrong with it, Chevy designed it to do that.
Old Jun 20, 2006 | 09:45 AM
Yeah it's designed that way but haven't you noticed that after sitting in traffic the car looses power from heat soak. It's like night and day before and after traffic. Not cool at all. Maybe the fan thing with HPTuners is the way to go. I don't know.
Mekanic's Avatar
most high temps at idle are caused by the synthetic oil thinning out. Not a huge problem is SS/SC as its been designed to use synthetics.
Old Jun 20, 2006 | 11:13 AM
GSoccer24's Avatar
i thought i saw a 160 degree thermostat somewhere but i haven't ever been able to find it again
Old Jun 20, 2006 | 11:20 AM
Matty's Avatar
It's not a great idea to change the temp at which the thermostat opens up. Like stated above, it's the temp good for this engine.
Old Jun 20, 2006 | 11:24 AM
RaineMan's Avatar
I've been looking for a constant-temp thermostat since I first got the car. Noone makes them for the Cobalts yet.
If you wanna see something strange... watch the engine temp in traffic when you turn the A/C on. It cools down nicely.
I also believe that the Cobalts run way too hot. Though 160 is gonna be too cold for our cars. I'd like to try a 180 or 200 degree.
Old Jun 20, 2006 | 11:36 AM
GSoccer24's Avatar
we have a 180, as stated above. most cars i know where there is a cooler thermostat offered lowers the temp by 20-30 degrees. this is especially beneficial for a modified SS S/C because the lower engine temps will reduce the chance of detonation. having 20 degree colder coolant won't harm anything at all.
Old Jun 20, 2006 | 11:49 AM
BooSSted's Avatar
If you want to cool the engine down, just hook up a power source to the fans and put them on a switch so you can flick them on when you want to. It works great when your at the track, you can cool the engine and not have it running!
Old Jun 20, 2006 | 11:59 AM
SilverSS/SC's Avatar
all you need to do is set the fans thru HPtuners . Both my fans run high speed all the time . All last week it was over 90* , cruising temps stayed below 185 ....typically 178-183 and sitting in traffic in never once got over 190* , even with air on . I do have redline water wetter in my coolant as well , which did help a little too .
Old Jun 20, 2006 | 12:28 PM
Tomtwtwtw's Avatar
A colder stat will only open the flow of coolant sooner than normal, however in heavy traffic it will eventually heat up to the same temp. You will also have to have the fans kick on sooner and stay on longer to see any real benefit, as once they turn off, your car will heat up again no matter how cold your stat is. Also, the only time one should be worried about heat soak is if they're going to race someone. The car running warm is actually most efficient, burning fuel cleaner and more completely, resulting in lower emissions and better milage. Sure, a colder stat and tweaking of the computer can give you lower coolant temps, but as a result you'll burn more gas and pollute more. Save that for the track!
Old Jun 20, 2006 | 12:36 PM
I really like this idea a lot. That's not hard to do. This is all good info so far.
Old Jun 20, 2006 | 01:13 PM
JapEatr's Avatar
South Central *********
with a colder tstat the computer is gonna dump more fuel in an attempt to heat the engine up to operating temps
you will run worse with colder tstat
the tstat has nothing to do with the fan coming on, you need a relay or as some ppl have said hptuners to set a lower fan cuton
vettes run 232degress b4 the fan comes on ours run 222, AND THATS OK
also ANY time you turn on the AC both fans come on(true on all cars), thats why the temps drop
Old Jun 20, 2006 | 01:17 PM
RaineMan's Avatar
Please prove to me that we have a 180* thermostat.
Most cars these days have a 200-210 degree stat.
Old Jun 20, 2006 | 01:23 PM
GSoccer24's Avatar
i thought it was mentioned at first. anyways, going with a colder thermostat by 20-30 degrees won't harm anything was my point, regardless if we have 180, 200, 200 or whatever it actually is. to get the max benefit you'd have to get the fans to come on when you want as well.
Tomtwtwtw's Avatar
It has a 180 or 185 stat...the way to prove it without looking at it is to see where the temp levels with the a/c on, as the fans are on constantly. Mine hovers between 180-185. The reason it doesn't get even lower is because the stat begins to restrict coolant flow in an effort to keep it at the optimal operating temp. All the stat does is open or close at a particular temperature. If we had a 210 stat, our cars would never run below 200 degrees once warmed up.
Old Jun 20, 2006 | 01:38 PM
I still think this is the best idea. I know 210 degrees is ok it's just when the car gets that hot it doesn't run as strong. There has to be a way to help this.
Old Jun 20, 2006 | 02:19 PM
max_boost's Avatar
Originally Posted by WopOnTour
Another old wives (mechanics?) tale IMO.
You'll have to explain to me the thermal dynamics of how a lower temp thermostat is going to make your engine run cooler.
A 160 stat just OPENS at a lower temp and THAT IS ALL, it doesnt "regulate" your engine temps- heat production levels and ability of the heat transfer system (pump, radiator, fans etc) do that. A stat opening point is more about regulating engine warm-up rate up to operating temperature and when flow through the radiator commences- not control what the peak temperature will be!
All a lower temp stat does is OPEN sooner, but your engine's heat production at load remains constant and the thermal transfer capabilities of the cooling system ISNT changed ONE IOTA with a lower opening stat. SO unless you are changing coolant FLOW somehow with a larger flow rate or improving the rate of heat exchange, switching to a lower Tstat does NOTHING.
JMO
Wop
I took this from the Red Line Fourms. What he says makes a lot of sense.
Old Jun 20, 2006 | 02:45 PM
Blown 4-banger's Avatar
If you change the thermostat without reprograming the fans its not gonna help anything. The thermostat will open, but since the fans don't come on til like 220, you won't get any cooler with the thermostat just letting fresh 220 degree water in.
Old Jun 20, 2006 | 10:12 PM
OK so changing the thermostat won't do the trick. What will then?
Old Jun 20, 2006 | 10:22 PM
max_boost's Avatar
Using HPTuners to turn the fans on earlier.
Old Jun 20, 2006 | 10:32 PM
sethallen's Avatar
has anyone hooked the fans up to a toggle or anything? (i dont have $500 for hptuners)
