Cooler Thermostat for the Balt?
Originally Posted by SilverStreak
I've been looking for a constant-temp thermostat since I first got the car. Noone makes them for the Cobalts yet.
If you wanna see something strange... watch the engine temp in traffic when you turn the A/C on. It cools down nicely.
I also believe that the Cobalts run way too hot. Though 160 is gonna be too cold for our cars. I'd like to try a 180 or 200 degree.
It does this because when the a/c is turned on, the radiator fans kick on, no matter what temp the coolant is at. This is why I run my a/c at the racetrack while I'm in the staging lines. The car is actually cooler this way when you're ready to run.
Originally Posted by CTCOBALTSSS
So the only way to fix this heat issue is to set up a switch in the car to turn the fans on when you want or run your A/C. Interesting....
look for the fan relay under your fuse box. on most other cars you just ground one leg of this with a switch mounted in the cabin and this opens the relay "cleanly".
if you dont want to messing around with all this electrical stuff you could just by-pass the relay completely with a fan controller from summit or something.
or you could do what i do on my poor old overheating saturn and use the factory fan switch (turn ac on for 3 seconds)
roth
Sep 26, 2015 12:16 PM
