cooling the hp maker
Old Apr 8, 2007 | 11:56 AM
blacksssc06's Avatar
ok i have a ss/sc i have a dry shot of nos and im putting 60 injectors and a 2.6 pully well the nos act like a cooling mod in the mid rpm range if i shot it off than or well i have to do more cooling mods?
Old Apr 8, 2007 | 12:01 PM
poppagun's Avatar
i am pretty sure ur goin to have to do more cooling mods but it should help a little.
Old Apr 8, 2007 | 12:10 PM
Shortbus's Avatar
How are you runing a dry shot?
Old Apr 8, 2007 | 12:14 PM
what do you mean how like what jet size
Old Apr 8, 2007 | 12:18 PM
zinner's Avatar
Moderator Alumni
Question, what is the max MAF freq you are seeing?
nitrous will actually increase heat inside the engine quite a bit. It might cool the intake track but don't count on that for any extra safety.
I like the stage 3 intercooler end plate. It's needs some elbow grease to install but it's tested by GM.
Old Apr 9, 2007 | 12:01 AM
not sure got a stage5 cpu from intense and i was looking more to get rid of the heat soak in the superchager and adding a little more hp 16whp right now with the jet i have in
Old Apr 9, 2007 | 12:05 AM
Shortbus's Avatar
No just how its working for you, and how are you spraying, zinner you may want to chime in on this, since you spray wet, and though about dry.
Old Apr 9, 2007 | 12:26 AM
well right now i have0.021 jet which at a bottle press of 900 its about 20 extra hp like i side not a big gain and im going to have it redynoed to check the a/f ratios
Old Apr 9, 2007 | 01:59 AM
MacG321's Avatar
That end plate, i heard it works great with a stage 2 tune. How does this work and how much of a benefit do you receive for all the elbow grease and 250$ spent?
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
footballplaya3k
Sep 28, 2015 11:14 AM
Superslowbaltt
Sep 24, 2015 06:11 PM
