Cooling Mist Help?
Old Jul 24, 2007 | 06:14 PM
scotts2.0's Avatar
Cooling Mist Help?
I've finished installing a new trunk mounted Coolingmist System. Pretty easy install. The problem is that its not turning on once it hits the 10psi pressure trigger. I have good power & I've tested the vacuum line for kinks and also made it turn on using a hand pump, but it doesn't come on with boost. I'm tee'd into the boost line coming off of the SC. Any ideas on what could be happening to cause the coolingmist pump not to come on??
Old Jul 24, 2007 | 08:21 PM
RoelSS's Avatar
I have the cooling mist, but I didn't install the 10psi trigger. I know the instructions say that you can adjust the boost by turning the screw inside.
I'm going to sell mine because it didn't work in conjuction with stage 3. It worked much better when I activated it manually and cut it off manually. I already ordered my nitrous kit!!
Old Jul 24, 2007 | 08:26 PM
redline24's Avatar
I would just try to adjust that boost pressure switch.
Old Jul 31, 2007 | 10:06 AM
TurboTommy's Avatar
Old Jul 31, 2007 | 10:13 AM
WSFrazier's Avatar
I have a boost activated Meth kit as well. Either adjust the boost pressure switch, or tie it into a different line. I have mine connected to the evap line coming off the top of the intake manifold, above the supercharger.
Old Jul 31, 2007 | 10:18 AM
SKDR112888's Avatar
you said you have in T-ed off the line on the supercharger, well that might be why if its any of the lines Im thinking of you wont get Boost pressure, T into the line on the top on the intake manifold right behind the supercharger gonig to the bypass soleniod that bleeds boost after 12.5 or whatever number it is.
hope that helps,
Old Jul 31, 2007 | 10:42 AM
TurboTommy's Avatar
He's right...it's suppose to be tee-d into the bypass line
Old Jul 31, 2007 | 12:12 PM
Area47's Avatar
Rent me! per hour
tap the line comming off the manifold, not the blower.
dennis69
Oct 20, 2015 04:49 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
Superslowbaltt
Sep 24, 2015 06:11 PM
