cooling mist water injection help
Old Jul 6, 2009 | 09:57 AM
venum_us_2002's Avatar
so reading on there site it does not say how much a turn does on the boost switch. Supposedly from cooling mist the pump is supposed to come on at 10psi. Yesterday i wired in a LED to show me when the pump turns on and i checked it. It is not coming on until around 14-15psi. Now is that because our gauges or in accurate or is it the boost switch. It did take a long time for my led to turn on in a 2nd gear pull from 40mph, probably came on at around 55ish mph at WOT
Old Jul 6, 2009 | 09:59 AM
ShortStack's Avatar
There is an adjustment that allows you to control when the pump will activate, per boost.
Old Jul 6, 2009 | 10:04 AM
i know that, i am wondering though if it realy is 10psi and my guage is fualty. AND how much does it adjust with what amount of turning to the 5/64 screw (ex, 1 full turn = 1psi?)
Old Jul 6, 2009 | 10:32 AM
ShortStack's Avatar
No, very minute adjustments.
Although it may be different from other switches, so you should check the manual.
Old Jul 6, 2009 | 10:37 AM
manual didnt say it, you can download the manual via coolingmist.com
Old Jul 6, 2009 | 10:40 AM
ShortStack's Avatar
Hmm.. weird...
Old Jul 6, 2009 | 10:55 AM
dvscobaltSS's Avatar
yeah i have it and it doesnt take much adjustment to change it. i have it spray at 10lbs on the stock gauge and my interceptor says something like 6lbs
Old Jul 6, 2009 | 10:57 AM
any idea why my LED doesnt turn on until around 14psi? should i adjust it or could my gauge be off
Old Jul 6, 2009 | 04:43 PM
nicksredline's Avatar
it could be the switch was not actuily set at 10 lbs... why don tu try to change it and see what happens.
Old Jul 6, 2009 | 06:30 PM
yeah i would change it i am sure they are not all perfectly set
Old Jul 29, 2009 | 02:39 PM
Soofisahab's Avatar
Check the switch boost range, there are different types....from what I remember, there were 5-15 psi and 15-? switches
Old Jul 29, 2009 | 02:48 PM
hungryhip-ccp's Avatar
My switch was set close to 10psi but not right on, i wouldn't worry about that too much.
I found that turning the Allen screw counter clockwise 1 turn will decrease the activation by approx 2psi give or take a little. If i were you i would turn it down 2-3 turns till it activates at 5psi and work your way up from there.
The pump/system has a little lag in it, i would set for 8psi if you want it to come on at 10, and so on.
Use compressed shop air and hook it up to the switch with a vac/psi gauge tee'd in and adjust the switch that way.
By looking at your L.E.D. source for a switching refrence.
This is what i do...
dennis69
Oct 20, 2015 04:49 PM
nathan112i
Sep 30, 2015 07:12 PM
Slick_Nick
Sep 28, 2015 09:15 PM
SlowSaturn
Sep 28, 2015 11:03 AM
