Cooling mod questions
Old Feb 4, 2012 | 11:23 PM
cole3883's Avatar
Alright guys im getting my stage kit installed soon and before i do i need some additional cooling mods. Im going to be running a 2.8 so nothing drastic but i want opinions on OTTP's & ZZP's dual pass endplate. Also what will i see better IAT's with the dualpass or option b? Eventually ill be getting a heat exchanger but i just want a lil something that will hold me over. thanks guys
ohhh and idk how to use the search button because it sucks ****.
Old Feb 4, 2012 | 11:31 PM
Jaredssbalt's Avatar
Dual pass for iats. Opt b doesn't effect your iat really, it just keeps your cooling system working at maximum efficiency. As for brand it doesnt matter both do the same thing, ones not going to work better than the other.
Old Feb 4, 2012 | 11:37 PM
ssblackstealth's Avatar
corn gas ftw....
just get a heat exchanger, dual pass isnt worth the hassle...
really just getting a meth kit would be your best option for cooling......
Old Feb 4, 2012 | 11:38 PM
cole3883's Avatar
ight thanks man. the reason i asked about brands is because ottp makes theirs from our stock endplates and zzp actually designed one.
Old Feb 4, 2012 | 11:49 PM
mrbelvedere's Avatar
you need to learn how to use the search button there are plenty of threads about this already
Old Feb 5, 2012 | 02:38 AM
nhanson's Avatar
are you on crack?
Stock quad pass is HORRIBLE.
1. Dual pass
2. Heat exchanger
3. Phenolic spacer
I recommend in that order
Old Feb 5, 2012 | 02:45 AM
turbosmart4's Avatar
i dont understand why mr belverde or wtv tries to be hard on EVERY post. he is asking nicely.
Old Feb 5, 2012 | 03:09 AM
Mr.N00bLaR's Avatar
Bigger/better HE + option B is good stuff. Meth makes magic happen to from what I read. You might want to look into the griffin HE, not cheap but from what I've seen people like it.
belligerence..lol.
Old Feb 5, 2012 | 03:17 AM
wow u actually took some time to find a troll pic ehhh
anyways look at my "join date" ...yes im new
Last edited by turbosmart4; Feb 5, 2012 at 03:17 AM. Reason: Automerged Doublepost
Old Feb 5, 2012 | 05:10 AM
cole3883's Avatar
hahah im glad you noticed he thinks hes hard too! ^^ but thanks to the people that acutally helped i appreciate it!
Old Feb 5, 2012 | 07:54 AM
ULWizSS's Avatar
Yeah on a 2.9 i needed no cooling mods according to hp tuners. Once i droped to a 2.8 you could see temps were to high to do back to back pulls.
I would go HE first and go from there.
Old Feb 5, 2012 | 09:36 AM
no im not there has been 93545657665858548748676545345454746746766655655585 78578754875485748548548547857857857857857854854785 78578574858547857857858566345142222132213909228298 1902939848576548392845765483924854934857658493485 threads on the subject so searching out an answer wouldent be that difficult
no im not hard its the forum rules but you cant get off the spoon feeding tit long enough to read or use the search button you want to be spoon fed like most
Old Feb 5, 2012 | 09:39 AM
zfissette's Avatar
do all cooling mods. not kidding. all mods possible = win. dual pass + phenolic spacer and option b is a good start. then add stg 3 he and the griffin later. then meth.
Old Feb 5, 2012 | 12:24 PM
Owen S's Avatar
Besides the trolling. I'll give my $0.02
Coming from John Powell, the best thing to do is Griffin Heat exchanger + dual pass + option B. Probably most expensive but yields best results bar none.
For the economical people aka myself, i have ottp HE + phenolic plate + dual pass + option b.
Go with ZZP for the phenolic plate, dual pass, and option b. cheaper/better customer service than OTTP from what I've been reading.
Only reason i have the ottp HE is because it was used, good condition, right price.
and ya, there are TOONS of topics on this...
Old Feb 5, 2012 | 11:26 PM
cole3883's Avatar
thank you guys!
Old Feb 5, 2012 | 11:45 PM
exactly what im gonna do! :
Old Feb 7, 2012 | 01:12 PM
Superman_Davin's Avatar
I have the ZZP S3 H/E, dual pass + opt B, and just recently added the phenolic spacer. I cannot believe the difference that spacer makes. Next stop for me is meth.
Old Feb 7, 2012 | 09:11 PM
cavfiredesire's Avatar
Ive been curious about the same thing....
The OTTP plate is a modded OEM plate....seems like it would fit better?
Old Feb 8, 2012 | 07:39 AM
zfissette's Avatar
the zzp plate is a perfect fit and looks much better.
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
