Cooling questions
Old Aug 4, 2010 | 10:23 PM
Nabes07SS's Avatar
Cooling questions
I notice my car runs consistantly between 170-180 degrees. I would like it in the 160 range. Have any of you put a lower temp t-stat in to help keep internal temps a bit lower? Yes, no? Good,bad?
Old Aug 4, 2010 | 10:51 PM
SunburstSS's Avatar
ummm thats totally perfect man, mine runs around 185 almost all the times during the summer, the engine needs to be over 170 and less than 190 to run to specs, so your fine and dont worry about much...
Old Aug 4, 2010 | 10:56 PM
mexi_loco's Avatar
just because YOU want the car to run cooler doesn't mean the CAR wants to, or will run more efficiently. It's efficiency point is actually about 185*.
Old Aug 4, 2010 | 11:03 PM
EcoTecDriver's Avatar
xmillion
Old Aug 4, 2010 | 11:04 PM
mexi_loco's Avatar
you're stalking me Tom, aren't you?
Nabes07SS's Avatar
Ha, good point.
Old Aug 4, 2010 | 11:08 PM
mexi_loco's Avatar
the only time you have to worry about cooling mods is when you start lowering the size of the supercharger pulley. But that's usually because you want to avoid heat soak. But there are several threads about that already.
Old Aug 4, 2010 | 11:09 PM
yea thats it
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
