Corsa Sport Catback Installed W/ Video
Originally Posted by Gramps
99% sure i will get this exhaust. Can you give some details on install? I will most likely do it myself. Only other exhaust I may consider is the Vibrant if it is out by the time I have my money.
1. Unbolt factory system from the downpipe/cat assembly (3 bolts).
2. Cut the factory system in half just in front of the rear axle. Plan the cut carefully so you are able to remove rear section of the old exhaust. This will be critical if you are using jack stands or ramps to elevate the car. Also I highly recommend buying/borrowing/renting a chain style pipe cutter to make the cut. Nice, clean, and easy.
3. Install the Corsa. Comes in 3 sections. Make everything "just tight" until you have all the sections installed and adjusted properly. Then torque all connections. Notice that the clamps the Corsa system ships with can be torqued about 3 times before they are junk so you can loosen the connections a couple of times for adjustments down the road.
4. Enjoy!
get your car back together for the meet today i have a buddy of mine with a lighting that wants to race. i can pull him from a 45 roll and he plays catch up until about 80 to 90 then has a car or two by 130 so with the smaller pulley full exhaust and header i think you should not have a problem. he will call a race from a stop and will beat the **** out of you but i will lamo when i see the look on his face when he loses to a cobalt with the 45 roll
We are going to post the 5% off discount code for anyone to use as we have received a lot of emails requesting it.
The discount code is "CORSA5" it is good for 5% off the Cobalt Corsa Exhaust systems, sport or touring.
Free shipping is also being offered, already setup on the site!
Let us know if you have any questions with this system.
Originally Posted by Chevypowered
Its nice to dream sometimes isn't it?
Originally Posted by Mercury
That exhaust tip looks silk!
I worked out for the price of the corsa exhaust you can get
GM cat-back
GM 4 inch Tip
GM headers
Decsion decsions
Originally Posted by p7x
EXACTLY looks so good and sounds decent. Pricey though!
GM cat-back
GM 4 inch Tip
GM headers
Decsion decsions
GM cat-back
GM 4 inch Tip
GM headers
Decsion decsions
Just to let you guys know the exhaust is real easy to install. This is his brother which installed it by myself with two jack stands, cutting wheel, and a couple of wrenches. It took me all of 75 mins to install including rounding up the tools and putting everything away. I own a Jetta GLI with a APR 2.5" exhaust which cost normally around $1k but I got mine for $800 shipped. It is one of the best exhausts on the market and is worth every penny. I can say the same about the Corsa. The welds, and the ease of installation due to the proper length and build of the Corsa makes it better than the rest. He has also dynoed the car with 3" pulley and CAI. He will be dynoing it sometime soon I hope because I want to put mine on the rollers and hopefully pull some close numbers. I honestly have nothing against Magnaflow but if you are going to buy an exhaust you might as well save your money and buy it once.
That is the dyno chart SAE corrected. As a few people said there not bad for a one wheeled Cavi.
GOOD GOD MAN THAT WAS F*CKING GREAT!!!!!!!
just got home from hearing his exhaust and all i can say is WOW
if you are looking to get an exhaust this one sounds great. at idle just a little louder that stock but when he got on it at a 40 roll i almost shat myself that is how good it sounded. and with the 2.7 on there header full exhaust full cai over my 3.0 drop in filter and muffler swap
i got a great look at those tail lights though. so did that lightning no matter what excuses he gave
great job on the car. now i need to make more money for more toys.
great job on the car. now i need to make more money for more toys.Haha that lightening guy was trying to think up excuses for the reason he got beat by a 4 cylinder. Uhh couldn't hear you guys beeping. Those were some sweet runs.
Originally Posted by CobaltSS422
I'm still confused.. So the GMPP Exhaust IS made by BORLA?? 2.5" Piping.. I just tried to look up the exhaust from Borla on their website and they don't list it anymore but i remember reading it was 2.25" mandrel bend piping? Is the GMPP mandrel bend as well?
http://www.crateenginedepot.com/stor...arts-C144.aspx
Maybe theres more info there
Originally Posted by vic_romano
where did you snag it for 480 shipped?
