Cracked # 4 piston
Old Dec 21, 2009 | 09:27 AM
jcutler's Avatar
Cracked # 4 piston
Ok just a question, I have had the balt less than a month. Right now my number 4 piston is cracked. Any idea where I can get a set of stock/forged pistons for a decent price. Also, does anyone know a ballpark on what someone would charge to put them in?
Thanks!!
Old Dec 21, 2009 | 09:36 AM
selfinfliction's Avatar
pistons are $4006 and $4006 for install
Old Dec 21, 2009 | 09:43 AM
jcutler's Avatar
Ummm no dude. I have purchased them for other cars, Imports and FORGED pistons were anywhere from 500-900 bucks depending on brand.
Why reply with a smart alec comment.
Old Dec 21, 2009 | 09:45 AM
rallyracer's Avatar
Thats for all 4 right?
Old Dec 21, 2009 | 09:47 AM
1BADSS/SC's Avatar
GM recommends eagle connecting rods, and diamond forged pistons. Buy the LSJ build book. All the parts and part numbers you would need are in there.
Old Dec 21, 2009 | 10:03 AM
jcutler's Avatar
Yes!!!
Thanks man!!
Any idea where I can buy the LSJ build book, I saw a PDF but I would like to have the actual book
Old Dec 21, 2009 | 10:07 AM
1BADSS/SC's Avatar
Yes!!!
Thanks man!!
crateenginedepot.com
Old Dec 21, 2009 | 10:08 AM
was thinking the same lol. will use this for later reference.
op look in classifieds
JapEatr's Avatar
South Central *********
check out ottperformance.com
they have rods for 1k and pstons/rings and clips for 600
install will take you a weekend
also if you are looking for ultimate reliability i would suggest Darton MID sleeves as well
they are 685 + Darton will install them for 600 if you mail your block to them (10day turnaround)
Old Dec 21, 2009 | 10:32 AM
jcutler's Avatar
So it is something I can install myself, I have all the tools and what not just never done work on the block just bolt ons.
Would it be better in the experience of a Mechanic?
Any ideas how much I am looking at labor.
I had a fellow forum member help me discover the cracked piston. Shout out to his help.
He took out the number 4 spark plug and it had oil on it. I guess a classic sign of a cracked piston. not to mention I am leaking oil and my car sounds like a SUBY.
Prior to the cracked piston I had a clogged cat and was boosting upto 20 psi with nothing but back pressure so I am guessing this caused the crack.
Any ideas what I need to buy besides the piston and rings. He said a hone, but I will be honest I have an idea of what it is but don't see why I need it. Any info would be great guys thanks for the help!!!
Old Dec 21, 2009 | 10:34 AM
MrSlickSter06SS's Avatar
Wow, man that sucks gotta spend all that money, hope it all works out for you.
Old Dec 21, 2009 | 10:37 AM
jcutler's Avatar
Thanks man sucks I had the car a month. Put on stage 2,CAI DP/HEADERS/CBE, just ordered 2.9 and 60 pound injectors was about to take it to get a tune and BAM this happens. I guess this gives me an excuse to build the engine.
Old Dec 21, 2009 | 11:45 AM
i respond to dumb questions with dumb answers.
Old Dec 21, 2009 | 01:58 PM
jcutler's Avatar
Explain how it was a dumb question dude? People asking for help when there car is not functioning as it should be or when they don't know the answer. That is what forums are for tool bag. Troll else where.
Old Dec 21, 2009 | 02:20 PM
Cefaln452's Avatar
dont get gm performance pistons... either wiesco or Diamond
Old Dec 21, 2009 | 02:24 PM
1BADSS/SC's Avatar
GM recommends diamond for the LSJ. Theyre about $900 for the set, but well worth it from what Ive heard.
Old Dec 21, 2009 | 02:52 PM
it was dumb because clearly you never even attempted to search for it as they are listed all over the internet, from alot of vendors here and even some used sets in the for sale section.
make some effort
Old Dec 21, 2009 | 02:54 PM
shroogis's Avatar
Uh...Huh??
http://www.ottperformance.com/store/...L-LSJ-4p56.htm
Old Dec 21, 2009 | 03:07 PM
Cefaln452's Avatar
Diamond all the way... thats what i have and that is what gm uses to replace their bull **** pistons in their build book
Old Dec 21, 2009 | 04:27 PM
jcutler's Avatar
make some effort
Clearly I did search, I checked the FS thread and nothing recent for sale. I did a google search on cobalt 2.0 headers and nothing of help came up plus I had several other questions. Get a life dude seriously.
Anybody have an idea on what I am looking at to have a single piston installed?
Old Dec 21, 2009 | 04:36 PM
1BADSS/SC's Avatar
Originally Posted by shroogis
this was back when vendors just started stockign them. Like right around when GM just released the stage 3 kit for the LSJ.
Old Dec 21, 2009 | 06:54 PM
insylem's Avatar
Wink
Oil on a plug for a cracked piston???
THere are several things that could cause oil on a spark plug.
Leaking valve cover gasket, where the gasket goes arround the plug hole
Leaking head gasket
Excessive Valve guide/stem clearances
-Worn Valve guides
-Worn Valve stems
You could just be running really rich
You may just have worn piston rings
Do a compression test.
Borescope the cylinder through the spark plug hole to see if
you can see the crack.
If your gona pull the pistons out,
Check them with a penetrant inspection. Basicly it seeps into cracks,
and makes small cracks show very easily. If they are fine, swap the rings,
rehone the cylinders, measure your cylinders and pistons out. Sounds like
your in for at least a partial overhaul anyway. Check the valve stem/guide clearances
and valve seats.
Old Dec 21, 2009 | 09:15 PM
jcutler's Avatar
Leaking head gasket
-Worn Valve guides
-Worn Valve stems
and valve seats.
Thanks for the info, I am going to take it to the stealership and have them dick with it. Once it comes to the block I am stupid.
Old Dec 21, 2009 | 10:00 PM
cobaltguy889's Avatar
First off welcome to the club. secondly, I'd reccomend diamond racing, you can probably stick with the stock rods unless you are going for crazy hp. Rod bearings and save your pennies to replace all the bolts and get a cosmetic headgasket and arp headstuds, along with The random little stuff and you are good to go. Your probably looking at 1200 bucks..... Arround that, when it's all said and done
I just read the whole thread, if I were you I would do a little investigating before you buy pistons, definately run a compression test, are you getting blowby?
Last edited by cobaltguy889; Dec 21, 2009 at 10:00 PM. Reason: Automerged Doublepost
Old Dec 21, 2009 | 10:06 PM
chris88z24's Avatar
lsj ftw
