Cracked # 4 piston
Old Dec 22, 2009 | 07:40 AM
jcutler's Avatar
Originally Posted by cobaltguy889
First off welcome to the club. secondly, I'd reccomend diamond racing, you can probably stick with the stock rods unless you are going for crazy hp. Rod bearings and save your pennies to replace all the bolts and get a cosmetic headgasket and arp headstuds, along with The random little stuff and you are good to go. Your probably looking at 1200 bucks..... Arround that, when it's all said and done
I just read the whole thread, if I were you I would do a little investigating before you buy pistons, definately run a compression test, are you getting blowby?
Thanks for the advice? Sorry whats blow by?
Old Dec 22, 2009 | 07:47 AM
gdubs's Avatar
Originally Posted by jcutler
Ok just a question, I have had the balt less than a month. Right now my number 4 piston is cracked. Any idea where I can get a set of stock/forged pistons for a decent price. Also, does anyone know a ballpark on what someone would charge to put them in?
Thanks!!
I hate you sig.... AHHH ROLLED
Old Dec 22, 2009 | 07:49 AM
shroogis's Avatar
Originally Posted by 1BADSS/SC
this was back when vendors just started stockign them. Like right around when GM just released the stage 3 kit for the LSJ.
Ahhh, gotcha!
It's where the compression rings in the piston have greater clearance to the cylinder wall and oil gets past the rings and burnt in the combustion chamber.
The car will blow dark smoke out of the exhaust (burning oil).
Because the clearance between the piston rings and the cylinder walls are greater, fuel can also be forced past the rings into the engines oil, which dilutes it and can cause premature wear to the bearings because the oils sheering/cooling properties has now changed.
Old Dec 22, 2009 | 08:31 AM
a_joyner's Avatar
Just out of curiosity what kind of tune did you have on it? Canned? Custom? Stock?
Old Dec 22, 2009 | 12:43 PM
jcutler's Avatar
GM stage 2 crap tune or reflash or whatever. And no smoke coming out.
Old Dec 23, 2009 | 08:44 AM
jcutler's Avatar
Well the stealership quoted me for 1900 dollars just in labor to replace a single piston. This is honestly not something I can do. So I am going to do some research but I need some ideas on what I can do. Looks like something I am going to have to do myself. They are saying they need to take the block out, which I know is not required.
What tools am I going to need to do this, I have a couple how to guys. But I guess I am going into this ***** deep. I have a general knowledge of the car.
FYI, anyone that wants to help me install this I would be willing to throw a pioneer in dash/dvd/nav/bluetooth set your way. I would even install it if local. Really need some help here. This is my DD.
Old Dec 23, 2009 | 10:15 AM
cobaltguy889's Avatar
gm is going to rape you with labor. Your better off finding a different shop.
Where are you located? I might be able to help.
Old Dec 23, 2009 | 10:23 AM
0redline6's Avatar
ahhh #4... lol when it happend to me i just did the work myself.. took a little less then a full weekend and 2 12 packs with a friend.. i personally think the lsj engine is easy as hell to work on.. i didn't run into any huge problems. I would get the eagle rods and diamond pistons. I have a few friends with that set up and tehy can't complain and love the added security. grab a set of ARP head studs cometic head gasket and your good to go and a new cat... or just take it off completely haha
Old Dec 23, 2009 | 10:37 AM
Clearly I did search, I checked the FS thread and nothing recent for sale. I did a google search on cobalt 2.0 headers and nothing of help came up plus I had several other questions. Get a life dude seriously.
Anybody have an idea on what I am looking at to have a single piston installed?
took me 30 seconds
https://www.cobaltss.net/forums/show...t=pistons+sale
Old Dec 23, 2009 | 11:00 AM
jcutler's Avatar
Yea I found that and PM'd him before starting the thread. His pistons are already sold, thats an old thread
Thank you though!!
Thanks man!! I am located right outside Charleston SC. I called a local tuner shop, they want about a grand to do it. I guess which seems about fair. But obviously I am going to try and get the best quality work for the lowest price.
I ordered the GM book for the LSJ from crate engine depot. So hopefully that will help. What special tools are needed for the job. Are they expensive etc?
Old Dec 23, 2009 | 12:29 PM
  #36
Piston ring compressor
torque wrench in/lb and ft/lb
Cylinder wall hone depending on how the walls look
I personally don't see you needing rods. The pistons are the weak point of the lsj. Rods themselves are pretty strong
I have spare stock pistons laying around if you are looking to just throw some in
Last edited by cobaltguy889; Dec 23, 2009 at 12:29 PM. Reason: Automerged Doublepost
Old Dec 23, 2009 | 12:34 PM
  #37
1BADSS/SC's Avatar
Its when oil comes out of the engine through the intake. Its kind of like the engine coughing up phlem....
Old Dec 23, 2009 | 12:38 PM
  #38
SeanEE89's Avatar
Originally Posted by selfinfliction
it was dumb because clearly you never even attempted to search for it as they are listed all over the internet, from alot of vendors here and even some used sets in the for sale section.
make some effort
Guys like this are what make me hate this forum. Stop being a douche and lend a helpful hand if you're going to take the time to post in the thread. Otherwise move on and stop being such a negative low life.
Good luck getting your car running though jcutler.
Old Dec 23, 2009 | 12:56 PM
  #39
jcutler's Avatar
Thanks man!!! I used to be in your neck of the woods. I lived in NoVA before I came down here.
And I agree, some of the kids on these forums are just trolls who care about a post count.
Old Dec 23, 2009 | 12:58 PM
  #40
06blackg85ss's Avatar
there in you fail, I had sets of pistons rods, bearings and whatnot for sale, thread was near the top of the fs section for over a week
Old Dec 23, 2009 | 01:01 PM
  #41
jcutler's Avatar
Are they sold?
I am guessing they were sold before this thread was even created. I have been in and out of the for sale section for the past week and never saw a set of pistons being sold. Anyways, your post is not contributing to this thread. Just trolling. Move on
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Cptnslo
Sep 24, 2015 09:32 AM
