cracked header? need help
Old Mar 13, 2008 | 04:45 PM
Nussle's Avatar
Unhappy cracked header? need help
last night, i was making a few runs against my friends civic Si for the fun of smoking him... then i noticed my car was sounding like it had a whole in the exhaust and **** was rattling every once in a while. so i got under my car today and couldnt see anything wrong really untill i saw cracks where each bolt that mounted the header on, they are just straight cracks tho, so im not sure if the header is in fact cracked or the stock header is like that. im kinda new to this ****, so try and help me out.
Old Mar 13, 2008 | 04:55 PM
Red2.4SS's Avatar
If it is cracked enough to leak then soot will build up in that area. You should be able to hear and smell the leak too!
Old Mar 13, 2008 | 05:00 PM
LScoupeTUNER's Avatar
doesn't sound good....haha
edit: wrong section?
Old Mar 13, 2008 | 05:25 PM
braineater's Avatar
moved.
Old Mar 13, 2008 | 05:26 PM
rallyracer's Avatar
post up pics.
Old Mar 13, 2008 | 05:33 PM
FunkyStickman's Avatar
There's a good possibility it's the flexpipe that's split. Without pics, it's hard to say, but check the flex section carefully. My Redline is bone stock and the flexpipe split in half with only 30,000 miles on it.
Nussle's Avatar
im pretty sure now that i see that pics that it is the problem, and damn its rusted.
Old Mar 13, 2008 | 05:35 PM
Red2.4SS's Avatar
That is a normal expansion joint that was built into it from the factory.
I see no sign of leakage!
red2006SS's Avatar
yea i just fixed the same problem with mine. where the flex pipe is ended up cracking and made my car run like crap and sound like a pissed off lawnmower lol. it did the same thing you described with the rattling and so on.
Old Mar 13, 2008 | 05:39 PM
Nussle's Avatar
were exactly is the flex pipe? im guessing the coiled looking pipe that connects the header and downpipe?
Old Mar 13, 2008 | 05:40 PM
red2006SS's Avatar
that would be it
Old Mar 13, 2008 | 05:41 PM
SS33's Avatar
Like they said, that is not a crack, it is an expansion joint. No problems there, look elsewhere,, maybe your flextube?
My stock manifold, you can see the expansion grooves at the bottom
Stock downpipe, the flex pipe is on the far right, I would check there
Old Mar 13, 2008 | 05:50 PM
Red2.4SS's Avatar
Man you guys' **** gets hella rusty back east! Mine was still almost new looking!
You should be able to see lots of black soot near the leak area.
DANRICKARD
Oct 1, 2015 12:08 AM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
