Cracked piston, possible build in progress. Need some advice
Old Dec 30, 2009 | 04:33 PM
jcutler's Avatar
ok so just had the car checked out, my number 1 piston has a crack. So honestly I am not a car mechanic by any means. So I am going to get the Diamond forged pistons, a new head gasket, head studs, piston rings. Is there anything else I am going to need to buy to have this completed.
I am going to have to do the work myself unless I can find a shop to do it for 900 bucks or cheaper. Any ideas thoughts? Any special tools I will need etc?
HELP!!!
Old Dec 30, 2009 | 08:19 PM
selfinfliction's Avatar
if you broke a piston, you better drop the block and have someone check the sleeves
Old Dec 30, 2009 | 08:38 PM
Snakes709's Avatar
HELP!!!
If you arent a mechanic and dont know what your doing. Then i highly recommend not doing the work yourself. If you want it done right, pay someone to do it and it will most likely cost more then $900
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
