Crate Engine Magnetic Drain Plug
Old Feb 27, 2007 | 10:38 PM
05redline's Avatar
I was just wondering, did the Cobalts ever come with the magetic drainplugs from the factory that crate engine depot sells?
http://www.crateenginedepot.com/stor...P1751C193.aspx
Or are these the new style OE replacements GM is starting to use?
Old Feb 28, 2007 | 09:24 PM
05redline's Avatar
Simple question, did anyone here have one of the magnetic stlye plugs come on their car from the factory?
Old Feb 28, 2007 | 11:08 PM
bluecobaltss06's Avatar
I have done a LOT of ecotec oil changes...and I MEAN A LOT! and I have never once seen a magnetic drain plug on that motor.
Old Feb 28, 2007 | 11:59 PM
05redline's Avatar
Have you changed any 07s?
Anyone work in a chevy parts departmen? Can tell if the magnetic plugs are the new OE replacements, or if the standard drain plugs are still sold?
Old Mar 1, 2007 | 02:46 AM
97 Z Me Go's Avatar
I had one in mince since 500 miles when i did my first oil change. This is only because I put it in there. there is no negetive reason i know of not to get one. I consider this a GOOD "mod".
To answer your question. NO ecotecs do not COME with them. This is a GM part but its the same thread pattern for lots of other gm motors.
Old Mar 1, 2007 | 04:16 PM
Johnboy12358's Avatar
what is the benefit of a magnetic drain plug?
Old Mar 1, 2007 | 04:23 PM
05REDROCKET's Avatar
When you pull the plug any metal shavings will stick to the plug.
Therfore you can monitor if you have a large amount of shavings
and correct the problem before it gets bad!
Old Mar 1, 2007 | 04:38 PM
ItalianJoe1's Avatar
Thanks for reminding me, I gotta order one from my parts guy. All the GM stuff uses the same plug size, but for some reason ours is not magnetic. The one in my dads truck is the same plug but with the magnet. I gotta get one of those.
Old Mar 1, 2007 | 04:55 PM
Wow, I will be putting one on with the next change then.
Old Mar 1, 2007 | 07:08 PM
Yeah, I forgot about it until I changed my oil last week. Now it will be 4 months until I do it again, so I will probably forget by then. Oh well.
Old Mar 1, 2007 | 09:58 PM
05redline's Avatar
So it does thread fine? I guess I'll pick one up then.
Old Mar 2, 2007 | 08:49 AM
alleycat58's Avatar
How the hell does this car NOT have one from the factory?!?!?!?!?!?!?! Even my Cavalier had one OEM......damn, that's a huge oversight on GM's part if that's true...
Old Mar 2, 2007 | 08:59 AM
WSFrazier's Avatar
The transmission drain plug is magnetic, I know that much.
Old Mar 15, 2007 | 09:56 AM
refuge4's Avatar
I changed my oil yesterday and I replaced my plug with the magnetic one. It threaded fine and it is the same length plug. It just has a magnet on the end. The bolt head size is smaller on the magnetic one. I will have to look at my socket when I get home and see what size it was.
I would recommend this to anyone with a Cobalt. I should be a little extra safety for the engine. I will have to wait until next oil change to see if it is actually collecting metal shavings.
Old Mar 15, 2007 | 09:59 AM
Rangerondubz's Avatar
Werd?
Old Mar 15, 2007 | 08:43 PM
I bet it will have some metal on it. I will do it next oil change, but that is a ways off. I never remember to get one until I have the oil out of the car. The magnetic one should be a 15mm, which is the same as the stock one. Unless you are using a different magnetic one than the one on other GM products.
Old Mar 15, 2007 | 09:35 PM
refuge4's Avatar
I took the page that is on Crate Engine Depots page to my GM dealer. They had one in stock and I bought one from them. It was about $0.50 more with tax than Crate Engine Depot, but no shipping and handling. It is actually a 13mm. I know this because I did this last night and the socket is still sitting on the wrench. I don't know why GM would change it, but they did.
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
