cruise control
cruise control
posting on this one because i have the supercharged ss. My question is, is there a certain speed to set the cruise control. Becuase at one point i had to get it fixed, it worked once then i just tried today and it didnt work again, luckily took it to a better dealer becuase the one in my town is stupid and cant work on a freakin sport tranny. But was wondering if anyone has or had the same problem and what you did to fix it, or if there is something i could do, or if i am tring to engage it wrong or something?
Thanks!!
Thanks!!
well maybe the dealership i took it to will do that, have to get sychros changed, and my door fixed, luckily i am barely inside the warranty mileage so everything is covered, but thanks will look at that when i get it back and see if they changed it or not. Is there any way the one the first dealership put in could have blown in a day? if it was bad or something
i had the same problem, i put in my stage kit with th new computer and the problem went away atleast i thought, it was working for a few days and i was excited then about a week after installling my stage kit it stopped working again, im pissed about it and wondering what it could be
got it figured out. For some reason the clutch switch had a slight malfunction and would never turn off. So it wouldnt let me engage the cruise control. THanks though guys!!!
try pulling back on ur brake pedal.... this happens to me..... ur brake switch gets stuck and doesent release.... the car cant go into cruise control mode if the brakes are applied..... so if the switch is on, no CC.... that or a bad CC switch.... which also happened to me once
If you ride the clutch the car will throw a clutch sensor malfunction code and will prevent you from engaging the cruise control. If you disconnect the battery for 10 seconds or so it should clear the code and the cruise control should work. It is always possible that the clutch switch is just malfunctioning in which case you will have to buck up and go buy a new switch at the dealership.
Yea my clutch switch stopped working too and got it replaced...the other day it started acting up again...went underneath the dashboard and adjusted it up a little bit and it works perfecto!!!!
