cruise control
Old Dec 22, 2008 | 01:24 PM
danielincobalt's Avatar
cruise control
posting on this one because i have the supercharged ss. My question is, is there a certain speed to set the cruise control. Becuase at one point i had to get it fixed, it worked once then i just tried today and it didnt work again, luckily took it to a better dealer becuase the one in my town is stupid and cant work on a freakin sport tranny. But was wondering if anyone has or had the same problem and what you did to fix it, or if there is something i could do, or if i am tring to engage it wrong or something?
Thanks!!
Old Dec 22, 2008 | 01:29 PM
brickerenator's Avatar
i think it's 25mph+
you might want to check your fuse box for any blown fuses
look for the EXH fuse iirc...
Old Dec 22, 2008 | 01:41 PM
well maybe the dealership i took it to will do that, have to get sychros changed, and my door fixed, luckily i am barely inside the warranty mileage so everything is covered, but thanks will look at that when i get it back and see if they changed it or not. Is there any way the one the first dealership put in could have blown in a day? if it was bad or something
Old Dec 22, 2008 | 01:42 PM
i don't know really
mine blew after my o2 sensor shorted out
Old Dec 22, 2008 | 01:51 PM
hm, hopefully they can get mine fixed,i have to drive up to kentucky on the 26th and i really dont wanna have to have my foot on the gas the whole way up there
Old Dec 22, 2008 | 04:59 PM
stonny9's Avatar
once mine stopped working when I hit the brakes when I tried to reengage it it didnt work. Didnt work again until I started my car again.
Old Dec 22, 2008 | 05:20 PM
fmxr47's Avatar
i had the same problem, i put in my stage kit with th new computer and the problem went away atleast i thought, it was working for a few days and i was excited then about a week after installling my stage kit it stopped working again, im pissed about it and wondering what it could be
Old Dec 22, 2008 | 05:31 PM
sport08's Avatar
i hardly ever use cruise control
Old Dec 22, 2008 | 05:50 PM
Zach06CobaltSC's Avatar
You probably just blew the fuse.... Check the fuse in the engine bay.
Old Dec 25, 2008 | 07:45 PM
got it figured out. For some reason the clutch switch had a slight malfunction and would never turn off. So it wouldnt let me engage the cruise control. THanks though guys!!!
Old Dec 29, 2008 | 12:14 AM
clutch switch is messing up again. i think i am going to have to buy a new one. Anyone here got one they need to get rid of "2006 Cobalt ss/sc"
Old Dec 29, 2008 | 01:24 AM
SuperSport4's Avatar
try pulling back on ur brake pedal.... this happens to me..... ur brake switch gets stuck and doesent release.... the car cant go into cruise control mode if the brakes are applied..... so if the switch is on, no CC.... that or a bad CC switch.... which also happened to me once
Old Dec 29, 2008 | 02:44 AM
OriGinaL Condo's Avatar
Sounds like you just didn't turn it on again before trying to set it.
Old Dec 29, 2008 | 11:37 AM
tried turning it on and off and back on, nothing... all that happened was the "cruise engaged" flashed and never engaged
Old Dec 29, 2008 | 12:46 PM
Then it's gotta be the clutch or brake sensors. Warranty that bitch
Old Dec 30, 2008 | 10:31 AM
rnjmur's Avatar
If you ride the clutch the car will throw a clutch sensor malfunction code and will prevent you from engaging the cruise control. If you disconnect the battery for 10 seconds or so it should clear the code and the cruise control should work. It is always possible that the clutch switch is just malfunctioning in which case you will have to buck up and go buy a new switch at the dealership.
Old Dec 30, 2008 | 11:04 AM
tdipowered's Avatar
Yea my clutch switch stopped working too and got it replaced...the other day it started acting up again...went underneath the dashboard and adjusted it up a little bit and it works perfecto!!!!
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Extremespeed
Sep 29, 2015 04:34 AM
jrocstar
Sep 26, 2015 11:42 PM
Coballin13
Sep 25, 2015 08:43 AM
