custom exhaust ?
custom exhaust ?
ok i got a magnaflow axle back exhaust... all i need 2 do is finish the 2.5" piping 2 make it a cat back.. is there any other way make the custom exhaust straight and not do that little loop it has on a stock ss/sc catback??? its kinda confusing.. but basically im trying 2 save as much piping as possible..
I know you're trying to save money, but it'll be hanging waaaay low if you go under the rear axle instead of over. Custom Tubes Inc makes a bend so you don't have to worry about creating your own Custom Tubes over axle bend
I'm sure you could go under the axle, but i wouldn't suggest going straight (diagnally routing the pipe under to cut corners) without doing a couple 90 degree turns due to the proximity of the gas tank.
