Custom intake manifold thoughts...
Old Oct 17, 2008 | 10:56 AM
Speedytec's Avatar
I'm thinking about a complete custom LSJ intake manifold for my RWD car and for this I like to use suitable donor parts of another engine type.
If I'm correct our engine has a cilinder distance of 96mm. (= Distance between inlet ports)
Surfing around I found that a Nissan SR20DET engine has a cilinder distance of 97mm.
There are lot's of good (cheapish) aftermarket manifolds available for this engine, so welding an ecotec inlet flange onto a modified SR20DET manifold may give me a good starting point.
Anybody happen to have the inlet flange port dimensions/drawing of the SR20DET?
Or know other suitable engine types with ~96mm cilinder distance??
Thxs
Old Oct 17, 2008 | 11:01 AM
Omega_5's Avatar
I thought you were keeping the SC'd.
The SR20DET intake would be good to retrofit for a turbo build... but for an SC'd motor it would be kind of the *****. That is, unless you are still planning to move the SC to the lower part of the engine bay.
Old Oct 22, 2008 | 01:54 PM
Speedytec's Avatar
Keeping the SC, but I'm looking around for parts I maybe can use on my "lowered SC set-up" project.
If I can source a suitable manifold with runners, trumpet intakes and a nice plenum... Can save me a lot of time.
Sofar SR20DET manifolds are a good donor candidate with a bore pitch of 97mm and widely available. (Ecotec = 96mm)
The Honda K20A has lots of nice ones for my intended set-up, but only a bore pitch of 94mm. Probably too difficult to make fit...
Then the new Misubishi 4B11: 86 x 86mm and pitch 96mm. Exactly like an LSJ! Only quite new (Evo X), so still expensive for a donor parts. (But maybe a idea as source for good turbo manifolds?? I'm also dreaming of an 4B11T head on a Ecotec bottom. If that could be made to fit. )
Last candidate I found was the SRT4. Also a bore pitch of 96mm. Good internal design and even the intake port shape looks quite similar to the Ecotec's.
Hmmmm... Lots of options for my winter project.
DarrenGC
Dec 24, 2021 01:55 PM
no_ss
Oct 18, 2015 11:58 PM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
